Warning message
Cisco Unique Identifier in Wireshark?
Apr 10th, 2009
For the users of WireShark, when doing a packet capture is there a unique identifier where I can look the packet and tell if it came from a cisco device?
I was assuming mac address but not all Cisco start with the same mac. I would like to be able to filter out packets that tx from a cisco device.
Overall Rating: 4 (1 ratings)
greg.washburn Fri, 04/10/2009 - 11:23
Have you tried:
Edit > Preferences > Name Resolution > Check enable MAC name resolution.
This should then show the word "Cisco" in the mac address of all Cisco devices.
Alternatively, I would think you would need to build an expression like:
!(eth.src == 00:1b:8f:37:1a:88) and !(eth.src == 00:1b:8f:37:1a:87)
There is instructions in the help file for using partial macs and / or IPs instead of full IPs and / or macs.
