CW tftp failure
Apr 10th, 2009
When attempting tftp backup from certain devices the transfer fails with
a permission denied.
I've got 420 devices that can tftp config backups to the ciscoworks
server without issue. Three sequentially-numbered devices cannot. Below is the result of a
tftp test from a failing device, as well as a packet capture from the ciscoworks server.
ML-3560B#copy flash tftp
Source filename [/c3560-ipbase-mz.122-35.SE5/]? c3560-ipbase-mz.122-35.SE5.bin
Address or name of remote host []? 172.16.6.20
Destination filename [c3560-ipbase-mz.122-35.SE5.bin]? test.bin
TFTP: error code 2 received - 16739
%Error opening tftp://172.16.6.20/test.bin (Permission denied)
ML-3560B#show ip int br
Vlan1 10.193.1.131 YES NVRAM up up
No.
Time
Source
Destination
Protocol
Info
172.16.6.20
TFTP
Write Request, File: test.bin\000, Transfer type: octet\000
172.16.6.20
10.193.1.131
TFTP
Error Code, Code: Access violation, Message: Access violation\000
- please suggest !
Joe Clarke Fri, 04/10/2009 - 18:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
In order for TFTP to work, the file has to exist on the server first.
So, create an empty file in NMSROOT\tftpboot, and give casuser full control over the file. For example, create an empty test.bin in tftpboot. Then try your experiment.
