Quick Configuration Instructions on MDS 9000
Thanks Giuseppe, is very much appreciated. The only problem I have is that in order to use the CLI commands you need to be more familiar and know what you are doing.
I would be more confortable using the the GUI interface.
Is there a doc that shows or gives this info that you can share, please?
I know the Brocade switch very well, by using the GUI interface and not the telnet interface, (this is where you use the CLI commands).
