Apr 10th, 2009
I'm having an issue where I can sit on the PIX and ping everything on the internal network. I can ping everything I've allowed on the external network as well. However, I can't get traffic across the NAT to ping. Here's the config:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname another-fw1
access-list outside_access_in permit ip host NAMED-SOMETHING any
access-list outside_access_in permit icmp object-group icmp-sources any
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside
ip address inside
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0 0
static (inside,outside) netmask 0 0
access-group outside_access_in in interface outside
route outside 1
route inside
Lame Layout Example
If I changed the NAT'd devices gateway to the PIX, then it works fine. BTW: The gateway isn't mine and I'm sure there isn't any type of route pointing back to me. I'm typically coming in from an external IP and I guess that my traffic is getting pushed out another direction once it hits their network.
So, would Source NAT work? Never used it.. So, I have no idea.
roshan.maskey Sat, 04/11/2009 - 04:51
Hi Mike,
The NAT configuration you have done is okey. But the routing part seems to be giving you trouble.
You have configured two default routes:
route outside
route inside
You are getting problem due to second default route pointed to
Please make the second route more specific(don't used default route) e.g if you have network in inside section then use
route inside
Also see the translation and connection table
sh xlate
sh conn
mikefunk Sat, 04/11/2009 - 09:06
Thanks for the reply!!!
Sadly, I've tried that.. I've even removed the old inside route, saved the config, and rebooted the PIX.
It still produces this:
[ERR]route inside 1
Route already exists
mikefunk Sat, 04/11/2009 - 10:44
Without route to internal router
outside 1 OTHER static (What I added)
outside 1 CONNECT static (Shows by default since it's the interface)
inside 1 CONNECT static (Shows by default since it's the interface)
When I ping I get:
No route to from "Where I'm at" on the PIX debug log...
When I add the 172.16.x.x route
inside 1 OTHER static
When I ping now... I don't get the "No Route" but I don't get replies either.
Reminder, I can ping everything on the internal and external network from the PIX. However, Outisde in and Inside out doesn't work even though it's allowed...
