fax to mail problem
I had try fax to mail in a lab environment.
fax machine--1751V---E1 pri---2811---Exchange
i use the fax machine send a fax to 2811,and the 2811 router has received the fax then forward to Exchange's mailbox,it works.when i use Exchange OWA send a mail to fax=<phoneNumber>@2811.router.com,the fax machine on 1751V has detected a incoming call,when it receiving the fax,the fax machine prompt "memory is low".i try use WinXP fax service receive the fax,there are some error,prompt just recevice a part,not entire.how can i resolve the problem?
paolo bevilacqua Sat, 04/11/2009 - 00:52
  • Hall of Fame,
    Founding Member
Send "show controllers E1" taken on the 2811".
debug fax mta Output
*Apr 13 04:02:03.615: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_dot_check:
Not found the terminating Dot!
*Apr 13 04:02:03.615: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_buf_mgmt:
state=3
*Apr 13 04:02:03.639: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_buf_mgmt:
buffer offset=681, state=3
*Apr 13 04:02:03.639: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_dot_check:
state=3
buffer offset=738, state=3
state=3
*Apr 13 04:02:04.415: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_work_routine:
context(0x49D7C6F4), state=3
*Apr 13 04:02:05.087: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_dot_check:
*Apr 13 04:02:05.087: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_buf_mgmt:
state=3
*Apr 13 04:02:05.091: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_buf_mgmt:
buffer offset=57, state=3
*Apr 13 04:02:05.091: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_dot_check:
state=3
*Apr 13 04:02:10.239: //-1/xxxxxxxxxxxx/SMTPS/esmtp_server_engine_update_recipient_status:
faxmail status=7
*Apr 13 04:02:28.355: %ISDN-6-DISCONNECT: Interface Serial0/2/0:3 disconnected from 5555555 , call lasted 28 seconds
*Apr 13 04:02:28.387: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_get_statistics:
context(0x49D7C6F4), smtpStatus=14
*Apr 13 04:02:28.387: //-1/xxxxxxxxxxxx/SMTPS/esmtp_server_engine_update_recipient_status:
faxmail status=27
*Apr 13 04:02:35.127: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_generate_notification:
context(0x49D7C6F4)
*Apr 13 04:02:35.127: //-1/A6347DB1800C/SMTPS/rejectMessage:
mime: Total=6, Rejected=1, Ignored=3
*Apr 13 04:02:35.127: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_work_routine:
context(0x49D7C6F4), state=1
*Apr 13 04:02:35.611: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_work_routine:
Calling smtp verb: quit
*Apr 13 04:02:35.611: //-1/xxxxxxxxxxxx/SMTPS/esmtp_server_engine_closesocket:
Closing socket 1
*Apr 13 04:02:35.615: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_clear_state:
context(0x49D7C6F4)
Freeing RECIPIENT context (envelope=fax=[email protected])
*Apr 13 04:02:35.615: //-1/A6347DB1800C/SMTPS/esmtp_server_engine_work_routine:
Freeing SMTP ctx at 0x49D7C6F4
*Apr 13 04:02:35.615: //-1/xxxxxxxxxxxx/SMTPS/esmtp_server_engine_work_routine:
context(0x0), state=-1
*Apr 13 04:02:35.615: //-1/xxxxxxxxxxxx/SMTPS/esmtp_server_engine_process:
context is freed
paolo bevilacqua Mon, 04/13/2009 - 10:59
  • Hall of Fame,
    Founding Member
As mentioned before, post "show controllers E1" taken on the 2811 router.
rock981119 Mon, 04/13/2009 - 17:42
what's problem about controller E1, In this lab We use FXO--CONN---FXS.
I think is something wrong with the e-mail transform to Fax.
