04-11-2009 02:13 AM - edited 03-06-2019 05:07 AM
Hi. I have a 2960 switch connected to a 4500 L3 switch. Below are further details.
2960
int g0/24
switchport mode trunk
switchport trunk allowed all
int vlan1
ip add 10.1.1.2 255.255.255.0
no shut
ip default-gateway 10.1.2.254
4500
int vlan 2
ip address 10.1.2.254
no shut
int gi1/6
switchport trunk encap dot1q
no shut
*both ports are up/up
*from the 2960, i can ping vlan 1,10.1.1.2
The problem is that i am unable to ping the default gateway, 10.1.2.254 from the 2960.
I would really appreciate any help regarding this.
04-11-2009 02:23 AM
Can u check whats the encap on 2960 and confrim,make sure that its dot1q.
Mahmood
04-11-2009 02:40 AM
2960 is set to dot1q by default.
04-11-2009 02:48 AM
if u look at ur configs u have created the SVI for vlan 2,it should be created for vlan 1 due this its not working.
Mahmood
04-11-2009 03:22 AM
Yup, you gotta VLAN mismatch.
04-12-2009 09:35 AM
1. check encapsulation on 2960 whether it is dot1q
2.give ip address to vlan 1 in network 10.1.2.0 255.255.255.0 on 2960
3.you are able to ping vlan 1 ip from 2960 because it is present on 2960 switch itself.
Thanks & regards,
suryakant chavan.
