Naviguate into CCM and UC filesystem
Jaime Valencia Sat, 04/11/2009 - 15:12
there are no guides or explanation on what files are on each folder. all you can do is use the CLI file commands to browse the few directories that are available
if there is a need due to install or something, instructions will tell you were to browse
there is no real need to browse dirsystem for regular operations
java
if this helps, please rate
