CCM 6.x transferring ringlist.xml via SFTP
nomykhan
H,
I am having problem in transferring the ringlist.xml file from the secure FTP.
here is what i am trying to do,
On the ccm CLI -- file get tftp Ringlist.xml
Please wait while the system is gathering file info...done
Number of file in Bytes:1
Total size in Bytes:2241
Total size in Kbytes: 2.1884766
Would you like to proceed [Y/N]? ...here I press Y to proceed.
SFTP Server: 10.1.0.18 (here I put my IP where CuteFTP is running)
SFTP Server port [22]: 22 ....here I press 22 to proceed.
User ID: ccm ...here I put the user account I created in my machine with administrator privilege
Password:
Download Directory: C:\\sftp .....here I put the directory of the CUTEFTP default Download Folder.
Could not connect to 10.1.0.18 port 22. Please verify sftp setting.
Note that I disabled my windows firewall and my Antivirus all throughout the procedure.
I am using CUTEFTP for the transfer.....
can someone let me know what is the issue?
Ayodeji Okanlawon
Use free ftpd from here...http://www.filetransit.com/download.php?id=43296
It works very well
Please rate all useful posts
It connects successfully but no file is transferred .....it comes to the admin propt again...
here is the log from the FTP
04-14-2009 11:56:55 SFTP server stopped
04-14-2009 11:56:59 SFTP server started
04-14-2009 11:58:52 IP 10.1.15.4 SFTP connection attempt
04-14-2009 11:58:58 IP 10.1.15.4 SFTP ccm access denied
04-14-2009 11:59:03 IP 10.1.15.4 SFTP ccm disconnected
04-14-2009 11:59:08 IP 10.1.15.4 SFTP connection attempt
04-14-2009 11:59:12 IP 10.1.15.4 SFTP ccm access denied
04-14-2009 11:59:18 IP 10.1.15.4 SFTP ccm connected
04-14-2009 11:59:22 IP 10.1.15.4 SFTP ccm is changing dir to / (C:\Program Files\freeFTPd\sftproot\ccm\)
04-14-2009 11:59:27 IP 10.1.15.4 SFTP ccm disconnected
04-14-2009 12:04:58 IP 10.1.15.4 SFTP connection attempt
04-14-2009 12:05:03 IP 10.1.15.4 SFTP joey@al-naghi.com access denied
04-14-2009 12:05:07 IP 10.1.15.4 SFTP joey@al-naghi.com access denied
04-14-2009 12:05:12 IP 10.1.15.4 SFTP joey@al-naghi.com disconnected
04-14-2009 12:05:16 IP 10.1.15.4 SFTP connection attempt
04-14-2009 12:05:21 IP 10.1.15.4 SFTP joey@al-naghi.com access denied
04-14-2009 12:05:27 IP 10.1.15.4 SFTP joey@al-naghi.com access denied
04-14-2009 12:05:31 IP 10.1.15.4 SFTP joey@al-naghi.com access denied
04-14-2009 12:05:36 IP 10.1.15.4 SFTP joey@al-naghi.com disconnected
04-14-2009 12:08:31 IP 10.1.15.4 SFTP connection attempt
04-14-2009 12:08:36 IP 10.1.15.4 SFTP ccm access denied
04-14-2009 12:08:56 IP 10.1.15.4 SFTP ccm disconnected
04-14-2009 12:09:00 IP 10.1.15.4 SFTP connection attempt
04-14-2009 12:09:05 IP 10.1.15.4 SFTP ccm access denied
04-14-2009 12:09:10 IP 10.1.15.4 SFTP ccm disconnected
04-14-2009 12:11:15 IP 10.1.15.4 SFTP connection attempt
04-14-2009 12:11:20 IP 10.1.15.4 SFTP ccm access denied
04-14-2009 12:11:25 IP 10.1.15.4 SFTP ccm access denied
04-14-2009 12:11:29 IP 10.1.15.4 SFTP ccm disconnected
04-14-2009 12:11:34 IP 10.1.15.4 SFTP connection attempt
04-14-2009 12:11:39 IP 10.1.15.4 SFTP ccm access denied
04-14-2009 12:11:44 IP 10.1.15.4 SFTP ccm connected
04-14-2009 12:11:48 IP 10.1.15.4 SFTP ccm is changing dir to / (C:\Program Files\freeFTPd\sftproot\ccm\)
04-14-2009 12:11:53 IP 10.1.15.4 SFTP ccm disconnected
04-14-2009 12:13:35 IP 10.1.15.4 SFTP connection attempt
04-14-2009 12:13:40 IP 10.1.15.4 SFTP ccm access denied
04-14-2009 12:13:45 IP 10.1.15.4 SFTP ccm access denied
04-14-2009 12:13:49 IP 10.1.15.4 SFTP ccm disconnected
04-14-2009 12:13:54 IP 10.1.15.4 SFTP connection attempt
04-14-2009 12:14:04 IP 10.1.15.4 SFTP ccm access denied
04-14-2009 12:14:09 IP 10.1.15.4 SFTP ccm connected
04-14-2009 12:14:13 IP 10.1.15.4 SFTP ccm is changing dir to / (C:\Program Files\freeFTPd\sftproot\ccm\)
04-14-2009 12:14:18 IP 10.1.15.4 SFTP ccm disconnected
Have u created the user you are trying to use in the freeFTPD server. You need to create the user and use the "harsh authentication" this will then allow you to add a pssword for the user. From the logs its obviuos that user does not have acess to the server.
HTH, pls rate useful posts
htluo
Level 9
Level 9
