BW restriction/control on switch port(access port)
Apr 11th, 2009
Core sw(vlan10) == Etherchannel== Access(Vlan10)Gi0/1 === Server (vlan 10).
Access sw = 2960
I need to restrict the BW on switch port where my server connected(gi0/1). I have to restrict my port utilization to 80% as my server pumping huge data on port Gi0/1 and it should not exceed to more than that.
ex: if it is fe port, Traffic/data flow should not cross the 80mb
Is there any option like rate limit on switch port
sateesh
Marwan ALshawi Sat, 04/11/2009 - 19:48
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
just do policing
for example
policy-map map1
class classdefault
police [amount in bit] confirm-action trasmit exceesd-action drop
then apply it to ur interface
intg0/0
service-policy map1 input
good luck
if helps rate
sateeshk10 Sun, 04/12/2009 - 07:26
I appreciate your prompt response..I will try and let know the details.
It seems to be how we apply on L3 interfaces like that only.I thought its something different on L2 network.
sateesh
sateeshk10 Sun, 04/12/2009 - 10:59
I hope As per the below config once it crosses the SET BW LIMIT packets are gets dropped. But I need it should not gets dropped it should be qued once its crossed the SET BW.
I hope once its gets dropped is packet resend again or it will dropped?
sateesh
