Set Commands Crashed IOS
Apr 12th, 2009
Hello All,
I am trying connect to my Cisco 3548 which is crashed via RJ45.Could anybody help me with the Set commands for RJ 45 Connections ?
MUHAMMAD SHAHEEN Sun, 04/12/2009 - 05:25
Cisco 3548 switches do not support set commands as these switches do not run CatOs but they are IOS based. To make changes into the configuration, you need to go to configuration mode by typing #configure terminal. just like you do in routers.
hope this helps....
ergonullu Sun, 04/12/2009 - 05:29
Unfortunately system is crashed during IOS upgrade.I need to install the old IOS back but could not login to the system.I have old IOS in my tftp local laptop but I need to define ip addresses for RJ45 connection over ethernet port.For that reason I need set commands for the switch
glen.grant Sun, 04/12/2009 - 10:18
If you end up doing xmodem then increase your console speed on the switch and your emulator to 115200 bps and a a 3548 image will take less than 10 minutes , if you leave it at the default it will probably take like 1 and half hours.
