Failed to backup MARS config
Apr 12th, 2009
[pnadmin]$ pnexp
Enter 'help' for a list of valid commands, 'exit' or 'quit' to exit.
pnexp> export config 10.25.71.3:/csmars
WARNING: this will stop CS-MARS, do you wish to continue (yes/no): yes
!!! The exported config data is saved under sub-directory of 10.25.71.3:/csmars/pnmars_2009-04-13-14-39-34
!!! Stopping CS-MARS processes ...
!!! Exporting config data now
Archive CF on demand failed, error code 1
Error: failed to export config data.
pnexp>
What does error code 1 mean? Only empty directories are created on the target.
tstanik Fri, 04/17/2009 - 12:49
  • Bronze, 100 points or more
I feel you are hitting bug. Config export failed for 4.3.6 while exporting config data to local disk. Check that the account you use has write access. Cisco recommends that you use the Cygwin SFTP Server on Windows
vldmegafondv Mon, 04/20/2009 - 15:53
I'm using MARS 6.0.2
NFS share have a full access (and chmod 777) from mars IP.
