DHCP
Apr 13th, 2009
I have 2 Access switch (6513) having multtiple VLAN , All are enabled for DHCP , But only sigle VLAN i am not getting DHCP IP , But Same time my reduntant switch same vlan i am able to get DHCP.
Richard Burts Mon, 04/13/2009 - 05:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Can you post the config of the switch that does not work and the config of the switch that does work? This might enable us to find the problem.
Rick
Nehoroshev Mon, 04/13/2009 - 05:33
Please write to the configuration of dhcp pool and configuration interface where dhcp is not working
