Restoring files of 6.1.1 to 6.1.2
Apr 13th, 2009
Hi all
Is it possible to built a server with 6.1.2 or 6.1.3 and restore the backup file from 6.1.1 ? Will all the configurations be loaded into the 6.1.2 as it was in 6.1.1 with none of the bugs ?
dhccoid.com Mon, 04/13/2009 - 05:06
It is only possible to restore a 6.1.1 config file to a 6.1.1 server. You will have to build a 6.1.1 server, then restor the 6.1.1 config and then upgrade to a leter version.
Jaime Valencia Mon, 04/13/2009 - 05:48
  • Cisco Employee,
  • Hall of Fame,
    2011
backups are meant to be restored ONLY on the EXACT SAME VERSION from which they were taken.
make sure you install the EXACT SAME 6.1(1) version on the new server to restore
java
if this helps, please rate
