authorization problem after upgrade IOS
Was working config on cluster member (WS-C2960-24-S) ios ver c2960-lanlite-mz.122-37.EY
aaa new-model
aaa authentication login default local group radius
aaa authorization exec default group radius if-authenticated none
aaa accounting exec default start-stop group radius
which allow a normal authorization from cluster-commander and direct connect to device via radius authorization.
after upgrade to c2960-lanlite-mz.122-50.SE.bin I got a error when i try logon via cluster commander. On debug I see as switch send authorization request to radius server with my username& password as "cisco" and got reject from serv.
Can this situation solved by additional config or I need fallback to previos ios ?
Leo Laohoo Mon, 04/13/2009 - 15:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The 12.2(50) has a number of very-basic bugs. I'd recommend you downgrade to 12.2(46)SE IOS.
Leo Laohoo Wed, 04/15/2009 - 14:41
  • Hall of Fame,
    2017 LAN, Wireless
Have you tried removing the AAA statements and putting them back in?
Leo Laohoo Thu, 04/16/2009 - 20:38
  • Hall of Fame,
    2017 LAN, Wireless
I take that back. Why don't you upgrade to the new 12.2(50)SE1 IOS?
gnijs Fri, 04/17/2009 - 09:58
  • Bronze, 100 points or more
Check your TACACS server configuration.
Are you using "single-connection" option ?
ip tacacs server x.x.x.x key yyyyy single-connection
If so, remove the single-connection option.
I have also run into "authorization failure" errors after an upgrade.
1) there is a bug known for TACACS when the switch received "unknown" TLV values.
When i removed the "single-connection" option, the problem went away.
2) We have also dug a bit further, and it also seemed to be related to the "device group" the device was assigned to in ACNS. When the switch was not defined in any group (default, just discovered) it didn't work. After the switch was assigned to the proper group, it worked.
mvg,
Geert
Why I need configure parameter for tacacs server if I don't using it ?
I debug situation and make conclusion a new ios doesn't right correct handle authorization process.
For example on IOS 12.2(37)EY we receive:
Apr 18 19:27:58: CLUSTER_MEMBER_12: AAA/MEMORY: free_user (0x1B24D5C) user='sergey' ruser='NULL' port='tty3' rem_addr='10.188.72.128' authen_type=ASCII service=LOGIN priv=15
Apr 18 19:27:59: CLUSTER_MEMBER_12: AAA: parse name=tty3 idb type=-1 tty=-1
Apr 18 19:27:59: CLUSTER_MEMBER_12: AAA: name=tty3 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=3 channel=0
Apr 18 19:27:59: CLUSTER_MEMBER_12: AAA/MEMORY: create_user (0x19B0948) user='sergey' ruser='NULL' ds0=0 port='tty3' rem_addr='10.188.72.128' authen_type=ASCII service=LOGIN priv=15 initial_task_id='0', vrf= (id=0)
Apr 18 19:27:59: CLUSTER_MEMBER_12: tty3 AAA/AUTHOR/EXEC (184998216): Port='tty3' list='' service=EXEC
Apr 18 19:27:59: CLUSTER_MEMBER_12: AAA/AUTHOR/EXEC: tty3 (184998216) user='sergey'
Apr 18 19:27:59: CLUSTER_MEMBER_12: tty3 AAA/AUTHOR/EXEC (184998216): send AV service=shell
Apr 18 19:27:59: CLUSTER_MEMBER_12: tty3 AAA/AUTHOR/EXEC (184998216): send AV cmd*
Apr 18 19:27:59: CLUSTER_MEMBER_12: tty3 AAA/AUTHOR/EXEC (184998216): found list "default"
Apr 18 19:27:59: CLUSTER_MEMBER_12: tty3 AAA/AUTHOR/EXEC (184998216): Method=LOCAL
Apr 18 19:27:59: CLUSTER_MEMBER_12: AAA/AUTHOR/LOCAL: no entry for sergey
Apr 18 19:27:59: CLUSTER_MEMBER_12: AAA/AUTHOR (184998216): Post authorization status = ERROR
Apr 18 19:27:59: CLUSTER_MEMBER_12: tty3 AAA/AUTHOR/EXEC (184998216): Method=radius (radius)
Apr 18 19:27:59: CLUSTER_MEMBER_12: tty3 AAA/AUTHOR/EXEC (184998216): Method=IF_AUTHEN
Apr 18 19:27:59: CLUSTER_MEMBER_12: AAA/AUTHOR (184998216): Post authorization status = PASS_ADD
Apr 18 19:27:59: CLUSTER_MEMBER_12: AAA/AUTHOR/EXEC: Authorization successful
and on IOS 12.2(50)SE1 receive:
00:18:37: %SYS-CLUSTER_MEMBER_15-5-CONFIG_I: Configured from console by sergey on vty0 (10.0.0.16)
00:18:40: CLUSTER_MEMBER_15: AAA/BIND(00000008): Bind i/f
00:18:40: CLUSTER_MEMBER_15: AAA: parse name=tty3 idb type=-1 tty=-1
00:18:40: CLUSTER_MEMBER_15: AAA: name=tty3 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=3 channel=0
00:18:40: CLUSTER_MEMBER_15: AAA/MEMORY: create_user (0x24C517C) user='sergey' ruser='NULL' ds0=0 port='tty3' rem_addr='10.188.72.128' authen_type=ASCII service=LOGIN priv=15 initial_task_id='0', vrf= (id=0)
00:18:40: CLUSTER_MEMBER_15: AAA/AUTHOR (0x8): Pick method list 'default'
00:18:45: CLUSTER_MEMBER_15: AAA/AUTHOR/EXEC(00000008): Authorization FAILED
00:18:47: CLUSTER_MEMBER_15: AAA/MEMORY: free_user (0x24C517C) user='sergey' ruser='NULL' port='tty3' rem_addr='10.188.72.128' authen_type=ASCII service=LOGIN priv=15
