problem with interface
Apr 13th, 2009
I have a router Cisco 2811 and I am trying to configure one Fastethernet interface, but I have some problems and don't know how to solve them.
I configure this interface like a LAN one and I connect a PC with a IP of the same subnet but the lights don't light and the protocol is down.
This is the configuration:
interface FastEthernet0/1
ip address 192.168.4.1 255.255.255.0
ip nat inside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
ip nat inside source list 102 interface FastEthernet0/0 overload
access-list 102 permit ip 192.168.4.0 0.0.0.255 any
This is the output of command : 'show interface fastethernet0/1':
FastEthernet0/1 is up, line protocol is down
Hardware is MV96340 Ethernet, address is 0024.14eb.8bb9 (bia 0024.14eb.8bb9)
Description: Conection to VLAN
Internet address is 192.168.4.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto Speed, 100BaseTX/FX
Last input never, output 00:00:09, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
63 packets output, 3797 bytes, 0 underruns
0 lost carrier, 0 no carrier
I've tried this configuration in other routers and it worked so I think the interface can be damaged .The router is a new one. I've tried the same configuration in the other interface and it worked with the same cable and PC.
I also have problems to connect via consola, because I can connect one time when I the router start up, but next times I can't see anything on the hyperterminal screen.
Anybody can help me to know if the interface is damaged and what is wrong with the consola?
Richard Burts Mon, 04/13/2009 - 06:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Marian
When I first read your post I thought that the issue was that when you connect the PC to the router that you use a straight through cable. When connecting a PC directly to the router interface you need a cross over cable.
I see that your post says that you have used this same PC and cable to connect to the other interface. Can you give us some details about this?
Rick
Leo Laohoo Mon, 04/13/2009 - 15:47
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Shouldn't be a problem with the cable Rick because the 2811's WAN interface are MDI/MDIX.
jimmysands73_2 Mon, 04/13/2009 - 09:03
  • Silver, 250 points or more
Could it be your plugging your PC into Fa0/0 instead of Fa0/1?
marianares0001 Mon, 04/13/2009 - 09:07
I am connecting the PC correctly. The other interface Fa0/0 is configured like a WAN interface and connected to another cable and it is working properly because I have connectivity from this interface.
Do you know any command to test the problem?
Thanks a lot
Leo Laohoo Mon, 04/13/2009 - 15:49
  • Hall of Fame,
    2017 LAN, Wireless
Have you tried to reboot the router?
Have you tried to upgrade the IOS?
marianares0001 Mon, 04/13/2009 - 23:30
I have rebooted the router several times.
Should I upgrade the IOS? to what version? It have Version 12.4(9)T7.
marianares0001 Tue, 04/14/2009 - 06:26
I've been looking for the IOS the router needs, and I've founded that is needed version 12.4(9)T, so I think it's not necessary to upgrade.
Any other ideas?? I don't know what to do.
Thanks a lot
marianares0001 Wed, 04/15/2009 - 06:09
I've configured in the router:
duplex auto
speed auto
It works like this with the same configuration, cable and PC with the other interface F0/0.
marianares0001 Thu, 04/23/2009 - 06:30
The speed is set to auto, so I dont think that is the problem. Some other ideas?
