local Directory
Answered Question
Apr 13th, 2009
hi all,
i'm working with cucm 6.1, and i want to configure local directory in the phones, so i'll be able to call from the directory of the phones, i ask your help (document, idea etc...)
any idea will be appreciated
best regards
Med
Correct Answer by Jaime Valencia about 8 years 3 months ago
corporate directory is under enterprise parameters and is not a service until 7.X, not sure what you're doing
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 04/13/2009 - 09:02
  • Cisco Employee,
  • Hall of Fame,
    2011
other than populating the end user info manually or pull info from AD to use the corporate directory we provide any other directory needs to be custom build
java
m.elmaaroufi Mon, 04/13/2009 - 09:12
hi
and thank you for your response
i configured the directory link in the phone services, and i create users manually, i subscribe the phone with the service, but it work only if i paste the url in the Service case, if not it doesn't work, the problem is i've paste the extension mobility url in this case so i need another solution without paste the directory url in the Service case
thanks
Correct Answer
Jaime Valencia Mon, 04/13/2009 - 09:14
  • Cisco Employee,
  • Hall of Fame,
    2011
java
m.elmaaroufi Mon, 04/13/2009 - 09:21
can you give a document which include the procedure of this operation
best regards
Med
