Changing Controller's Management IP
Apr 13th, 2009
Has anyone here changed the management VLAN of the controller? If so, what is the best way to do it?
I need to change the management VLAN of my controller. I already have everything in place, everything working but I need to change the VLAN ID of my controller's management VLAN. The IP would still be the same only VLAN ID will change. On all my access switches, I only allow specific VLANs and if I need to change the VLAN ID of the controller's management then I just need to go to each switch and add this new vlan to the allowed list. When this new VLAN has been added then I'll go ahead and change the VLAN ID of the controller.
Thank you in advance.
carenas123 Fri, 04/17/2009 - 07:07
Try the below configuration.
You can change the management VLAN settings via command line:
config interface vlan management ('0' for Untagged, or
number for specific tagged VLAN)
or through the GUI at:
Select --->Controller
Select ---->Interfaces
Select ----> Edit (for management interface)
Change ---> VLAN Identifier ('0' for Untagged, or number for
Click ---> Apply
