mike-greene Mon, 04/13/2009 - 11:22
  • Bronze, 100 points or more
I'm afraid it is. I just went through the same thing and if you put the SSL lic on the primary ASA it disables failover. Once I put the SSL lic on the standby I could enable failover again.
Richard Burts Mon, 04/13/2009 - 11:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Donny
I understand that there may be a feature in an upcoming release that may change this requirement. But at present yes it is required to purchase a separate set of licenses for the second ASA.
Rick
