Questions of internet config on a 2811 router
Answered Question
Apr 13th, 2009
Recently I had a task to configure a internet connection on a 2811 router, but i'm a newbie so not sure i did it correctly.
First of all, my router has only 2 Fast ethernet ports. Also, what's the purpose of backend IPs. Here is the config below (ip has been modified):
ISP config: Router Interface: CAR1.NWR1 PC105
Switch Port: MCD101.NWR1 :interface 1/0/18
Vlan: 141
Front-End IPs: 4.1.1.0/30 (Level3 side: 4.1.1.2, Customer side: 4.1.1.1)
Back-End IPs: 8.8.8.0/24 (Useables: 8.8.8.1 - 8.8.8.254)
My router config:
Current configuration : 1338 bytes
version 12.4
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname 120B_Internet
boot-start-marker
boot-end-marker
enable secret 5 $1$kEJE$bMaRvgVqPbrrJpdiBYarE1
no aaa new-model
resource policy
clock timezone est -5
clock summer-time EDT recurring
ip cef
no ip domain lookup
ip accounting-threshold 1000
voice-card 0
no dspfarm
interface FastEthernet0/0
description Link to ISP - Level3
ip address 4.1.1.2 255.255.255.252
ip accounting output-packets
duplex full
speed 100
interface FastEthernet0/1
no ip address
duplex full
speed auto
interface FastEthernet0/1.1
description Management VLAN 1 - Native Vlan
encapsulation dot1Q 1 native
ip address 8.8.8.1 255.255.255.0
no snmp trap link-status
ip http server
no ip http secure-server
logging synchronous
login
line aux 0
password 7 1316021F0609167372
login
line vty 0 4
password 7 04481E0B02245E1750
login
transport input none
line vty 5 1180
login
scheduler allocate 20000 1000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
i didn't create any acl and NAT yet. Please correct my config if it's wrong.
thank you very much!!
Correct Answer by thotsaphon about 7 years 10 months ago
Lei,
What you need to do for accessing the internet is as follows:
- Create a default route to pass traffic to ISP
- Create NAT statements and apply things
Toshi
Overall Rating: 5 (1 ratings)
Correct Answer
thotsaphon Mon, 04/13/2009 - 08:56
Lei,
Toshi
sukadelic Mon, 04/13/2009 - 09:14
thanks for your advise.
i guess my basic config on those interfaces are correct. I just need to create NAT and default route.
What do i do with back-end IPs though?
thotsaphon Mon, 04/13/2009 - 09:24
Lei,
Nothing to do with that. Just do things I mentioned.
HTH,
Toshi
sukadelic Mon, 04/13/2009 - 12:36
Toshi,
My setup is ISP->Router->switch->2 firewalls. Please tell me should I create NAT on the router or the firewalls?
thotsaphon Mon, 04/13/2009 - 12:47
Lei,
It depends. Do you have public ip addresses assigned between the router and 2 Firewalls? If not, You finally have to do NAT on the router anyway.
HTH,
Toshi
sukadelic Mon, 04/13/2009 - 13:10
yes. one public ip for the router and assign one of the back-end IPs for those 2 firewalls.
thotsaphon Mon, 04/13/2009 - 13:22
Lei,
Well,you have other networks behind 2 firewalls. In case you don't want to add routes on the router to route them back to firewalls. You can do NAT on the Firewall after that doing NAT on the router as well.
To be honest,you can implement the way you're familiar with.
HTH,
Toshi
