New switches not showing up in the DCR
Apr 13th, 2009
I am running CWLMS 3.0.1
We recently added several switches to the network, yet they don't show up int the DCR. They are not excluded, and they are sending traps to the LMS. I am not over my license number (yet). What else could be stopping them from showing up in the DCR?
Joe Clarke Mon, 04/13/2009 - 10:31
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Is this LMS server integrated with ACS?
davepeat2 Mon, 04/13/2009 - 12:55
No, it is not. I have some 230 switches that are in there, but the last few have not been discovered.
Joe Clarke Mon, 04/13/2009 - 12:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Okay, so are you adding the switches to DCR manually, or are you expecting Discovery to pick them up automatically?
davepeat2 Tue, 04/14/2009 - 04:53
I am expecting them to be picked up automatically. Other switches that are connected to them were discovered. They are in the same IP address range, same IOS version as other switches, etc.
Joe Clarke Tue, 04/14/2009 - 08:58
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the NMSROOT/conf/csdiscovery/CSDiscovery-config.xml as well as the output of show run for an affected device. If you cannot post this information, then please open a TAC service request.
davepeat2 Tue, 04/14/2009 - 11:52
Under Device Discovery I show that 461 Total devices discovered, 255 reachable devices (which are mostly the switches I want to manage), and 206 unreachable devices. I am only licensed for 300. Is this the problem? If so, how do I get rid of the unreachable devices. The RME collection shows only 247 devices in Inventory. And DCR shows 279 devices.
Joe Clarke Tue, 04/14/2009 - 12:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
License has nothing to do with this. DCR is unlicensed, and can support up to 50,000 devices. If devices are showing as unreachable, they must not be SNMP reachable using the community strings configured in Discovery.
davepeat2 Wed, 04/15/2009 - 04:27
I will check my SNMP community string.
Thanks again for all your help.
