Cisco Unity Bulk Import Wizard on Unity 5.0 (SMTP Notification)
Apr 13th, 2009
I'm using this tool just to add/modify the Message notification on actual users.
There is no problem on the output.log, or in the error.log, when i check the configuration under notification there is no mail,or enabled notification.
Just to make a note, the bulk works but never change/add the email address, or enables the notification.
Here is a sample file .csv that I used.
ALIAS,VMI_TEXT_SMTP_ADDRESS
Ggrader,[email protected]
