(TWO OUTSIDE INTERFACES) ONE FOR A HOST AND OTHER FOR OTHERS HOSTS
leandro.candido
Hi all,
I have a ASA 5510 with 2 interfaces outside that 2 internet links are connected it.
I need to do that a host in inside netwok goes out by a interface outise and others host goes out by other interface.
Someone know how can I to do this?
6 Replies 6
r.malviya
Hi ,
Please Update with more details wat exactly you want ..
1) You want policy based routing ( which not possible in asa)
2) You have inside network (10.10.10.0/24) & you have 2 differnet subnet which is connected to 2 different internet pipes , Your target if request is coming for the 1st network then its will move to 1st internet link & if request is coming for another subnet then it move to another internet link .which can be possible through Policy nat .
please update with details .
Ritesh Malviya
Malviya,
I beleave that PBR could solve this problem, but is not supported in ASA.
I have two internet links main and secondary (2 outside interfaces) and 1 inside interface.
I need to permit that a only host goes out by a of secondary internet link, while all others host goes out by the main link.
The subnet is the same.
roshan.maskey
This is possible only if all your inside network goes by doing PolicyNAT.
Lets consider the following.
interface outsideA: ip= A.A.A.A
interface outsideB: ip= B.B.B.B
interface insideH. ip=H.H.H.1
Your two hosts:
H.H.H.A and H.H.H.B
Note: This configuration only works if your inside host uses your outside interface IP for internet access.
Commands:
access-list internetA extended permit ip host H.H.H.A any
access-list internetB extended permit ip host H.H.H.B any
global (outsideA) 2 interface
gloabl (outsideB) 3 interface
nat (inside) 2 access-list internetA
nat (inside) 3 access-list internetB
Hi maskey,
I did what you suggest, but because I have two link I wasn't able to configure a default route for each link.
route internetA 0.0.0.0 0.0.0.0 x.x.x.x
route internetB 0.0.0.0 0.0.0.0 y.y.y.y
Someone know how can I configure two defaults routes in ASA?
The default routing pointing to internet should be like this:
Assuming your two outside interfaces are named:
outsideA
outsideB
the default route to internet should be:
route outsideA 0.0.0.0 0.0.0.0 x.x.x.x
route outsideB 0.0.0.0 0.0.0.0 y.y.y.y
Test the connection using packet tracer
source IP: H.H.H.A
src port: 2000
protocol: tcp
dest public IP: P.P.P.P
dst port: 80
Review the packet tracer output closely
repeat with inside ip: H.H.H.B
Roshan, did you get this working, trying to setup the same configuration (Two ISP's)
If so how did the routeing work ?
Thanks in Advance !
