04-13-2009 02:25 PM - edited 03-15-2019 05:27 PM
We have a NM-HDV2-2T1/E1 in a 2821 router. We have PRI's from a provider connected to both interfaces. We're seeing a few CRC errors on both interfaces. Currently, we have "no network-clock-participate" with both interfaces set to clock source line. We are planning to set the card to "network-clock-participate" and then "network-clock-select" on the first T1 interface. Then, setting the first T1 interface to clock source line and the second to clock source internal. Is this correct?
Solved! Go to Solution.
04-13-2009 02:34 PM
Leave default of clock source line for both interfaces. Set network-clock-select with a decreasing priority of your choice.
Note, you don't need the NM-HDV2 in a 2821. You can host the PVDM2 directly on motherboard, and the VWIC in the slots.
04-13-2009 02:34 PM
04-13-2009 05:47 PM
Great, thanks. Turns out we had spare NM-HDV2-2T1/E1's but no VWIC's. I made the change and will keep an eye on the interface errors. I'll mark this one as solved.
04-14-2009 12:03 AM
You should be able to reclaim the VWIC from the NM simply pulling it out.
Thanks for the nice rating and good luck!
