MOH on CUCM 6.13
Answered Question
Apr 13th, 2009
We would like to disable MOH on CUCM 6.13 cluster for all users.
which is be the best way?
- "set flag" to "no" on all MOH servers?
or
- Disable "Cisco IP Voice Media Streaming App" from the "service activation' window?
What needs to be restarted or rebooted if we pick any options above to disable MOH?
Correct Answer by Jaime Valencia about 8 years 1 month ago
A) stop the MOH servers as you mention
B) set the MOH in a MRG but do not add it to any MRGL
C) stop IPMVS but also causes CFB and MTP to be lost
java
if this helps, please rate
Overall Rating: 4 (1 ratings)
Correct Answer
Jaime Valencia Mon, 04/13/2009 - 17:52
  • Cisco Employee,
  • Hall of Fame,
    2011
java
