RV042 static NAT
Apr 13th, 2009
I'm using the RV042 router for using NAT.
but, I could not find to configure " Static Nat" in RV042.
For configuration ,It only support to based Web. right?
I know Cisco Router(C2811..etc) is able to support "STATIC NAT in console.
168.126.62.x  101  >  192.168.x.x   40001
168.126.62.x  102  >  192.168.x.x   40002
168.126.62.x  103  >  192.168.x.x   40003
Please let me know if you have any information that.
Thanks.
brasakai Fri, 04/17/2009 - 13:03
  • Cisco Employee,
Under "Setup" there is a "One-to-One NAT"  where you can map external IP addresses on the WAN port to specific internal addresses.  You are required to have multiple IP address.  You can also do port forwarding where you forward traffic from the WAN to a specific internal IP address based on incoming destination port.
