CME dial-peer matching
Answered Question
Apr 13th, 2009
Hi all,
Does anyone know why dial peer 11 below is matching for 00424123123 ?
It matches dial-peer 11 and drops the last 2 digits off. It should match dial-peer 12.
I have also tried with 0........$ as the dial-peer 11 pattern with no luck.
dial-peer voice 11 pots
description Local calls
destination-pattern 0........
port 0/0/0:15
forward-digits 8
dial-peer voice 12 pots
description Mobile and Long Distance
destination-pattern 00[2-9]........
port 0/0/0:15
forward-digits 10
debug voip dialpeer all...
Apr 14 15:55:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=11
Apr 14 15:55:34: //-1/B3EECCA7800C/DPM/dpMatchPeersCore:
Calling Number=, Called Number=004241231, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=004241231
Apr 14 15:55:34: //-1/B3EECCA7800C/DPM/dpMatchCore:
Dial String=004241231, Expanded String=004241231, Calling Number=
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Apr 14 15:55:34: //-1/B3EECCA7800C/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=11 Is Matched
Result=Success(0) after DP_MATCH_DEST
Apr 14 15:55:34: //-1/B3EECCA7800C/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=11
Cheers
Kent.
Correct Answer by MARWA AHMAD about 8 years 1 month ago
hi,
trydial-peer voice 11 pots
destination-pattern 0[1-9].......
port 0/0/0:15
forward-digits 8
this will work unless you have the 1st digit "0"for local calls
Overall Rating: 5 (1 ratings)
kplunkett512 Mon, 04/13/2009 - 22:12
It's finding an exact match and sending the call. That dial plan isn't going to work, as it's overlapping. I've attached a sample dial plan I use in the states for 10 digit local dial area codes. The last entry is a "catch all".
dial-peer voice 1 pots
description Dial-peer to LD
destination-pattern 1..........
port 0/0/0:23
prefix 1
dial-peer voice 2 pots
description Dial-peer to Local
destination-pattern [2-9].........
port 0/0/0:23
dial-peer voice 3 pots
description Dial-peer for 911 calls
destination-pattern 911
port 0/0/0:23
forward-digits all
dial-peer voice 4 pots
description Default Dial-peer to PSTN
destination-pattern .T
port 0/0/0:23
Correct Answer
MARWA AHMAD Tue, 04/14/2009 - 01:06
hi,
port 0/0/0:15
forward-digits 8
kent.plummer Tue, 04/14/2009 - 02:03
Thanks for the suggestion Marwa. I will give this a try in the morning.
From what I have read I thought dial peers were matched based on longest match. These suggestions seem to imply otherwise. Anyone able to clarify?
Kent.
