10 16:09:04: %SW_MATM-4-MACFLAP_NOTIF: Host 000e.d771.089e in vlan 12 flapp
Apr 14th, 2009
I wonder if you can help me, I am getting this error on both my edge switches - 10 16:09:04: %SW_MATM-4-MACFLAP_NOTIF: Host 000e.d771.089e in vlan 12 is flapping between port Gi1/0/23 and port Gi1/0/25 - see below.
Both switches are connected together and each switch also has a connection to Pix firewalls which are connected in a failover configuration.
At the moment the error does not appear to be service affecting but I want to make sure this does not become an issue and would really like to know why it happened. At the moment the error has not reappeared in the log since Friday but the only thing that happened on Friday which has since been rectified was a UPS failure, please advice and let me know if there is anything I nedd to check for.
Switch1#sh log
Switch1#sh mac-address-table
Mac Address Table
Vlan Mac Address Type Ports
12 000e.d771.089e DYNAMIC Gi1/0/25
Switch1#sh run int g1/0/25
interface GigabitEthernet1/0/25
description Link to Switch2
switchport trunk native vlan 12
switchport mode trunk
end
interface GigabitEthernet1/0/23
description Link to Pix1 Firewall
switchport access vlan 12
speed 100
duplex full
end
Switch2>sh log
Apr 10 16:09:04: %SW_MATM-4-MACFLAP_NOTIF: Host 000e.d771.089e in vlan 12 is flapping between port
Gi1/0/25 and port Gi1/0/24
Switch2>sh mac-
Mac Address Table
12 000e.d771.089e DYNAMIC Gi1/0/24
Switch2#sh run int g1/0/24
interface GigabitEthernet1/0/24
description Link to Pix2
end
Switch2#sh run int g1/0/25
description Link to Switch1
spanning-tree cost 2000000
end
Many thanks,
Martha.
Giuseppe Larosa Tue, 04/14/2009 - 01:26
  • Hall of Fame,
    Founding Member
Hello Martha,
the flapping MAC address is a Cisco MAC address you can check this at
http://standards.ieee.org/regauth/oui/index.shtml
This is probably the MAC address of a PIX check on your firewall.
you can verify if a failover occurred with
sh failover
on pix devices
if so nothing to worry about this is the trace of a failover between the two pix boxes.
Hope to help
Giuseppe
mfawehin Tue, 04/14/2009 - 03:12
Brilliant, thanks Giuseppe. I've checked and failover did occur between the Pix boxes. Its good to know I don't need to worry about it.
Cheers,
Martha.
