04-14-2009 01:32 AM - edited 03-06-2019 05:09 AM
Dear all,
is it possible to "say" a multilayer swtich (3750) which interface he should use for a tftp upload? With ping and trace I can, but is it for tftp for example also possible?
It would be helpfull for our firewall configuration on remote locations.
Thanks in advance
Sebastian
Solved! Go to Solution.
04-14-2009 01:39 AM
Hello Sebastian,
the interface on the path to destination is chosen normally.
to have a consistent behaviour you should use something like
ip tftp source-interface vlan10
in global config
Hope to help
Giuseppe
04-14-2009 01:42 AM
yes you can specify this by using following command using lo0:
ip tftp source-interface Loopback0
HTH,
Dario
04-14-2009 01:39 AM
Hello Sebastian,
in global config
Hope to help
Giuseppe
04-14-2009 01:42 AM
HTH,
Dario
04-14-2009 01:47 AM
Hey Guiseppe, Dario,
Thanks a lot for the fast replies, very easy and I didn't find it in the conf guide...
Best regards,
Sebastian
04-14-2009 02:25 AM
you can find it here:
http://www.cisco.com/en/US/docs/ios/12_0/configfun/command/reference/frgenral.html#wp1018371
HTH,
Dario
04-14-2009 02:43 AM
Great Dario....Thank's..
