Traffic from VPN IPsec to DMZ
Apr 14th, 2009
I have already configured IPSec VPN between router and ASA.
That is possible to reach hosts from remote location 192.168.201.0/24 via VPN to dmz-vlan13?
So I need traffic from 192.168.201.0/24 via VPN to be pated to the DMZ-13.
In log I found :
No translation group found for icmp src outside:192.168.201.2 dst dmz-vlan13:192.168.7.101 (type 8, code 0)
How is in such situation configure NAT/PAT?
Config partly:
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 1.1.1.2 255.255.255.252
interface GigabitEthernet0/2.13
vlan 13
nameif dmz-vlan13-proc
security-level 40
ip address 192.168.224.74 255.255.255.252
access-list outside_access_in extended permit icmp any host gw-outside
access-list inside_nat0_outbound_1 extended permit ip iib-inside-network 255.0.0.0 ATM-Network-201 255.255.255.0
access-list dmz-vlan13-nat extended permit ip host 10.0.11.73 host 192.168.225.101
access-list dmz-vlan13-nat extended permit ip host 10.0.11.73 host 192.168.225.97
access-list dmz-vlan13-nat extended permit ip host 10.0.2.27 host 192.168.225.101
access-list dmz-vlan13-nat extended permit ip host 10.0.2.27 host 192.168.225.97
access-list dmz-vlan13-nat extended permit ip ATM-Network-201 255.255.255.0 host 192.168.7.101
access-list dmz-vlan13_access_in remark # Allow all ip from dmz-vlan13-proc - from any
access-list dmz-vlan13_access_in extended permit ip any any
access-list outside_1_cryptomap_1 extended permit ip iib-inside-network 255.0.0.0 ATM-Network-201 255.255.255.0
access-list outside_1_cryptomap_1 extended permit ip ATM-Network-201 255.255.255.0 iib-inside-network 255.0.0.0
access-list outside_1_cryptomap_1 extended permit ip ATM-Network-201 255.255.255.0 192.168.7.0 255.255.255.0
access-list outside_1_cryptomap_1 extended permit ip 192.168.7.0 255.255.255.0 ATM-Network-201 255.255.255.0
access-list outside_1_cryptomap_1 extended permit ip 192.168.224.0 255.255.255.0 ATM-Network-201 255.255.255.0
access-list outside_1_cryptomap_1 extended permit ip ATM-Network-201 255.255.255.0 192.168.224.0 255.255.255.0
global (outside) 1 interface
global (dmz-vlan13-proc) 2 interface
nat (inside) 0 access-list inside_nat0_outbound_1
nat (inside) 2 access-list dmz-vlan13-nat
nat (inside) 1 iib-inside-network 255.255.0.0
static (dmz-vlan13-proc,inside) 192.168.225.97 10.0.11.97 netmask 255.255.255.255
static (dmz-vlan13-proc,inside) 192.168.225.101 192.168.7.101 netmask 255.255.255.255
access-group outside_access_in in interface outside
access-group dmz-vlan13_access_in in interface dmz-vlan13-proc
route dmz-vlan13-proc 10.0.2.1 255.255.255.255 192.168.224.73 1
route dmz-vlan13-proc 10.0.11.97 255.255.255.255 192.168.224.73 1
route dmz-vlan13-proc 192.168.6.0 255.255.255.0 192.168.224.73 1
route dmz-vlan13-proc 192.168.7.0 255.255.255.0 192.168.224.73 1
route dmz-vlan13-proc 192.168.224.0 255.255.255.0 192.168.224.73 1
route dmz-vlan13-proc 192.168.225.0 255.255.255.0 192.168.224.73 1
crypto ipsec transform-set ........
crypto map outside_map 1 set security-association lifetime seconds 28800
crypto map outside_map 1 set security-association lifetime kilobytes 4608000
crypto map outside_map0 1 match address outside_1_cryptomap_1
crypto map outside_map0 1 set peer 1.1.1.1
crypto isakmp enable outside
crypto isakmp policy 1
Thanks a lot!
it-iibank Tue, 04/14/2009 - 06:39
nat (dmz-vlan13-proc) 0 access-list dmz-over-ipsec
- that made zero nat, but I need PAT via
vlan 13
security-level 40
...in that interface several networks are routed like 192.168.7.0/24 192.168.6.0/24 etc.
sdoremus33 Tue, 04/14/2009 - 11:43
  • Bronze, 100 points or more
If you have the access-list (src= 192.168.20.1.0- 24 network to dst= 1.1.1.2 outside interface ip address of the ASA device you could try and add the following
static (outside,dmz-vlan13) interface 1.1.1.2 netmask 255.255.255.255. HTH
