Cisco Network Assistant and WS-C6509
Answered Question
Apr 14th, 2009
Could anyone tell me if the WS-C6509 is manageable via the Cisco Network Assistant.
By default, I cannot add this to any Community, though it is viewable as a device in CNA. I thought maybe an IOS upgrade? (boot system flash disk0:s222-advipservicesk9_wan-mz.122-18.SXF13.bin)
We have a lot of ports in this chasis and it would be very handy to have this access.
Kind regards
Kevin
Correct Answer by Marvin Rhoads about 8 years 2 weeks ago
Indirectly.
See the release notes for CNA (http://www.cisco.com/en/US/partner/docs/net_mgmt/cisco_network_assistant/version5_0/release/notes/OL12210a.html#wp699844). They state, in part, that:
"The Topology View of Network Assistant supports Catalyst 6500 switches. You cannot add these devices to a community or cluster, but you can start device manager for them from the Topology view."
Basically, they are saying that the full functionality of CNA is not available for the 6500. You can use CNA in conjunction with the CiscoView Device Manager. That product, however, appears to be somewhat orphaned (last update over four years ago - http://www.cisco.com/en/US/partner/products/sw/cscowork/ps4565/prod_release_notes_list.html) so you might not want to go with that option.
A full CiscoWorks LMS setup would certainly gives you lots of functionality (CiscoView, Campus Manager, RME, etc.), but along with it, a fairly high cost of ownership which may be too much for a small installation.
Hope this helps. Please rate this post if it does.
Overall Rating: 5 (1 ratings)
Correct Answer
Marvin Rhoads Tue, 04/14/2009 - 04:44
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Indirectly.
