how to upgrade cat 6500
Apr 14th, 2009
Hi all, if I want to upgrade the IOS on my cat 6500, do I just do it like normal switch, copy tftp flash ?
also, would this apply to both CPU's? or would I need to upgrade each independently?
also when I save config on the active CPU, does this automatically apply to the standby cpu ?
JamesLuther Tue, 04/14/2009 - 06:47
Oh yeah - and yes configs are synchronised between the sups.
You can run commands on the secondary sup with
remote command standby-rp
remote login standby-rp
and check running/startup config, bootvar, config-register etc.
