LMS 2.6 RME software repository errors..
Apr 14th, 2009
I have got all my devices with the exception of six in my repository.. I have attached the output from the failed devices. I know there are a couple where I guess the device credentials are still wrong, but the others I have no idea what is happening with them. Any input on what I am seeing would be great.
thanks,
Joe Clarke Tue, 04/14/2009 - 08:48
Diag images are not supported, so that explains most of these failures. The only other failure I see is for c3550-i9q3l2-mz.121-19.EA1c.bin, but without logs, or a specific version of RME, I cannot say what the problem is. Given that it's an import issue, I would check to make sure the image transport protocol (e.g. TFTP) is working between the device and server.
glynncounty Tue, 04/14/2009 - 09:22
RME version 4.0.6
I don't understand what you mean my diag images? I know i am pulling from the flash on the device is it something to do with that? I will double check TFTP..
Joe Clarke Tue, 04/14/2009 - 09:39
The images are diagnostic (see their names). They are not regular system images.
