Internet Access Problem behind ASA?
Apr 14th, 2009
I think it is probably an issue with the router, but I am going barmy so am checking everything. I should be able to access the internet from an internal address through the firewall to the router address.
Many Thanks for looking.
ASA Version 7.2(4)
hostname xxxxxxxxxxx
domain-name xxxxxxxxxxxxx
enable password xxxxxxxx encrypted
passwd xxxxxxxxx
names
name 22.22.22.23 ROUTER
name 22.22.22.22 OUTSIDE_IF
name 10.0.0.0 INSIDE_NETWORK
name 172.31.1.0 REMOTE_ACCESS
interface Vlan1
nameif inside
security-level 100
ip address 10.0.0.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address OUTSIDE_IF 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
access-list SPTNL extended permit ip INSIDE_NETWORK 255.255.255.0 REMOTE_ACCESS 255.255.255.240
access-list NONAT permit ip INSIDE_NETWORK 255.255.255.0 192.168.16.0 255.255.255.0
access-list S2STRAFFIC permit ip INSIDE_NETWORK 255.255.255.0 192.168.16.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool vpn-ras-pool 172.31.1.1-172.31.1.14 mask 255.255.255.240
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 ROUTER 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 10.254.254.27 255.255.255.255 inside
http 192.168.1.0 255.255.255.0 inside
http xxxxxx 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set xxxSET esp-3des esp-md5-hmac
crypto dynamic-map dynmap 100 set pfs
crypto dynamic-map dynmap 100 set transform-set xxxSET
crypto map xxxMAP 20 match address S2STRAFFIC
crypto map xxxMAP 20 set peer xxxxxxxxxxxxxx
crypto map xxxMAP 20 set transform-set xxxSET
crypto map xxxMAP 100 ipsec-isakmp dynamic dynmap
crypto map xxxMAP interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 20
telnet INSIDE_NETWORK 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
group-policy SMG-RAS internal
group-policy SMG-RAS attributes
wins-server value xxxxxxxxxxxxx
dns-server value xxxxxxxxxxxxxx
split-tunnel-policy tunnelspecified
split-tunnel-network-list value SPTNL
default-domain value xxxxxxxx
tunnel-group SMG-RAS type ipsec-ra
tunnel-group SMG-RAS general-attributes
address-pool vpn-ras-pool
default-group-policy SMG-RAS
tunnel-group SMG-RAS ipsec-attributes
pre-shared-key xxxxxxxx
isakmp ikev1-user-authentication none
tunnel-group xxxxxxxxxxxxxxx type ipsec-l2l
tunnel-group xxxxxxxxxxxxxxx ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:4ed029f0ea377e917fb3f8bd2e51a0d8
: end
