Cisco 877 Boot flash
mailaglady2
I have deleted my flash on a cisco 877 and my power went off as I was trying to download new image. My router don't boot at all now. It is on rommon 1 at the moment. What do I need to do, how can I update it from rommon mode?
Your assistance would be greatly appreciated.
2 Accepted Solutions
Lawrence,
Don't bring any network device back to home. You won't get enough sleep. (grin) Okay let's go to the point.
Your PC ip address is 10.1.1.1/24
Router will be configure ip address as 10.1.1.2/24
- Let's put the image into your pc. I mean,you have to put it into the path that TFTP server can pick it.
- Do you have a TFTP program on your pc? Let's install real quick.
- Open the TFTP server program.
- Plug the router and PC with the cross cable. I mean, A FastEthernet on the router.
At the router
rommon 1 > IP_ADDRESS=10.1.1.2
rommon 2 > IP_SUBNET_MASK=255.255.255.0
rommon 3 > DEFAULT_GATEWAY=10.1.1.254
rommon 4 > TFTP_SERVER=10.1.1.1
rommon 5 > TFTP_FILE=Put the exact ios name
rommon 6 > tftpdnld
Don't forget to read the link I provided as well.
Toshi
This is a more specific guide for the 870 series. The 'Disaster Recovery with TFTP Download' section reiterates some of the information already posted.
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/rommon.html
8 Replies 8
Lawrence,
In case you are in rommon mode. Are you missing the image as well? If so, please check this link out.
http://supportwiki.cisco.com/ViewWiki/index.php/The_tftpdnld_ROMmon_command_recovery_procedure_fails_due_to_invalid_syntax_or_variables
Just try to get a new image via tftp.
HTH,
Toshi
I dont get the option to get into the router.. below is the output of the router when I switch it on.
System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Copyright (c) 2006 by cisco Systems, Inc.
C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory
Booting flash:c870-advipservicesk9-mz.124-24.T.bin
Error opening: flash:c870-advipservicesk9-mz.124-24.T.bin
No bootable image file: flash:/
Unable to open boot file
rommon 1 >
Lawrence,
Just try to get the new one
The link I provided is kinda cool.
HTH,
Toshi
There's no image in flash. My problem here is I can't move from rommon>1 to get into the router, how can I get into the router?
I have access to our ftp server, the image is located into that server. I am at home with my laptop and these router, I have a modem that allows me connection to the internet.
Lawrence,
At the router
rommon 6 > tftpdnld
Toshi
I will have to continue tomorrow, my rj45 connectors are finished. will have to buy tomorrow, thanks man. I will sort it tomorrow.
