ACS 4.2, installing UDV
Answered Question
I am trying to install a user defined vendor data file using csutil. I can successfully install the UDV using csutil, but when I look in 'interface configuration' in ACS the new UDV is not showing. The command I am running is: 'csutil -addudv 7 symbol.ini' and it tells me it has installed successfully. I am running ACS version 4.2, here is my VSA file:
[User Defined Vendor]
Name=SYMBOL
IETF Code=388
VSA 1=SYMBOL-AUTH
[SYMBOL-AUTH]
Type=integer
Profile=out
Enums=SYMBOL-AUTH-Enums
[SYMBOL-AUTH-Enums]
1=Monitor Role
2=Helpdesk Role
4=Nwadmin Role
8=Sysadmin Role
16=WebAdmin Role
32768=Superuser Role
Can anyone shed any light on this?
Correct Answer by Jagdeep Gambhir about 8 years 1 month ago
Did you try reloading the ACS? Also first you need to add any device in network configuration using that VSA.
Now it should show up in Interface configuration.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Tue, 04/14/2009 - 06:17
  • Red, 2250 points or more
~JG
Jagdeep Gambhir Tue, 04/14/2009 - 06:43
Please mark this post resolved so others can be benefit.
~JG
