Trouble setting up VPN
Apr 14th, 2009
Hi all. I'm pretty new to Cisco, and need to setup VPN access on a newly purchased 1811w router. Basically I need a setup where company employees can access their work desktop from home.
I have followed the instructions found here:
http://cisco.com/en/US/docs/routers/access/1800/1801/software/configuration/guide/vpnezvpn.html
and after following the instructions, I have the following config file (see attached).
Currently, when I issue the following command in the CLI: "show crypto ipsec client ezvpn", I get the following reply:
Eazy VPN Remote Phase: 6
Tunnel Name: ezvpnclient
Inside interface list:
Outside interface list: FastEthernet0
Current State: IDLE
Last Event: CRYPTO_SS_UNUSED
Save Password: Disallowed
Current EzVPN Peer: 10.10.20.5
My question(s) is - Does the config look like it is setup correctly, and if it does how do I test it (I've never used a VPN before.)
Thanks for the help.
vmoopeung Mon, 04/20/2009 - 10:39
  • Bronze, 100 points or more
The SSL VPN Client (SVC) provides a full tunnel for secure communications to the corporate internal network. You can configure access on a user by user basis, or you can create different WebVPN contexts into which you place one or more users.
SSL VPN or WebVPN technology is supported on these IOS router platforms:
870, 1811, 1841, 2801, 2811, 2821, 2851
3725, 3745, 3825, 3845, 7200, and 7301
http://www.cisco.com/en/US/products/ps6496/products_configuration_example09186a0080720346.shtml#diag
