ISDN Error message - Can anyone help
darkbeatzz
I have Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c)
trying to do and ISDN test call and get the following erro
01:46:14: ISDN BR0/1/0 **ERROR**: host_disconnect_ack: Unfound B-channel on Disconnect_Ack call id 0x8005
01:46:36: ISDN BR0/1/0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x8005, event 0x5 ces 1
woods#sh isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0/1/0 interface
dsl 2, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 2 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
would anyone have any ideas?
10 Replies 10
lamav
Level 8
Level 8
Hi:
Can you post the config?
Are you sure about the switch type?
SPIDs?
What about the number you are dialing? Is it valid?
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094b76.shtml#deactivated
Victor
interface BRI0/1/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
isdn caller 1234455
no cdp enable
ppp authentication chap
ppp multilink
end
positive about switch type
I wonder does the image allow me to dial out?
woods#sh ver
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 25-Oct-05 17:10 by evmiller
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
woods uptime is 2 hours, 4 minutes
System image file is "flash:c1841-ipbase-mz.124-1c.bin"
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FCZ121794A1
2 FastEthernet interfaces
1 ISDN Basic Rate interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Mick
I do not think that it is an issue with the copy of IOS that you are running. As long as the IOS recognizes the BRI interface it should support dialing activity on the interface.
I believe that there is a significant hint about the issue in your original post:
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
If layer 1 is deactivated and layer 2 is not activated, then this is the first problem that you need to solve. I would suggest that you check on these things:
- is the router interface correctly connected to the circuit?
- is the circuit to which it connects activated?
- is the circuit to which it connects a digital circuit and not an analog circuit?
- I would suggest checking the switch type but you say that you are positive that this is correct.
Rick
Rick
when I try to call the router i can see the incoming call and the 3 layers look good.
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 80, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
Mick
I agree that this looks good up through layer 3. In your original post the ISDN layer 1 status was deactivated. In this post the layer 1 status is Active. Did anything change between the original post and this one?
If you are still having problems I would suggest that it might be helpful to have the output of debug isdn q931.
Rick
Rick
Hi Rick,
nothing has changed. the only thing I did was to make the call inbound which brings up all the layers.
here is debug q931
18:36:24: ISDN BR0/1/0 **ERROR**: host_disconnect_ack: Unfound B-channel on Disconnect_Ack call id 0x8023
18:36:46: ISDN BR0/1/0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x8023, event 0x5 ces 1
Likely a bug, try upgrading to 12.4(3j).
woods uptime is 20 hours, 15 minutes
I can not find anything on the image in the software advisory to check for bugs etc. it does not recognise the image name!
I have upgraded to
woods#sh ver
Cisco IOS Software, 1841 Software (C1841-IPBASEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 16:11 by prod_rel_team
woods uptime is 10 minutes
System returned to ROM by reload at 11:43:59 GMT Wed Apr 15 2009
System image file is "flash:c1841-ipbasek9-mz.124-24.T.bin"
and the issue is now resolved.
thanks for your help
Hello Mick,
under the BRI interface you need commands to specify how the router should do the call
isdn caller is just a call screening on received calls
you need to use
dialer string
or
dialer map ip
commands to make the router able to perform a call for DDR purposes.
Edit:
you are using a dialer interface so you need to put the calling commands under the dialer interface that uses pool 1.
You haven't provided your interface dialer config so the notes above are valid for the logical interface.
Sorry for the confusion.
Hope to help
Giuseppe
