how to change default Vlan
Answered Question
Apr 14th, 2009
Could be changed the default Vlan (not native vlan). does exist any command to change it? i want to switch number from vlan 1 to X vlan without manually move all ports.
thanks.
Correct Answer by Edison Ortiz about 7 years 9 months ago
The default vlan will always be Vlan 1 and it can't be changed.
You can change a group of switchports from the default Vlan 1 to Vlan X by using the interface range command, for instance:
switch(config)#interface range fx/1-48
switch(config)#switchport access vlan x
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
thotsaphon Tue, 04/14/2009 - 08:32
Adriatik,
I'm not sure that I understand your question.
Let's say VLAN 10.
What about these command?
(conf)#vlan 10
(conf)#interface range g0/1 - 24
(conf-ran-if)#swi acc vla 10
Toshi
Correct Answer
Edison Ortiz Tue, 04/14/2009 - 08:34
HTH,
__
Edison.
