SBS Server
Apr 14th, 2009
Client has an SBS server and not after putting in a UC500 can't access the remote site.
UC500 has XO T1 line.
No DHCP on uc500.  SBS is handling that.
When thru cca and configured NATt for ports 80, 443, 4125, 3389 to 192.168.16.2 IP address of the server.
Still nothing?
Steven Smith Tue, 04/14/2009 - 08:49
I am confused by your description as to the problems you are having.
Another device can do the DHCP for the UC500, but they should be on the same network.  Is the SBS server also routing packets?  What is the topology?  Does the remote site VPN to the SBS box, or to they connect to the UC500?  Can you provide a topology?
Steven
Maulik Shah Wed, 04/15/2009 - 09:53
Is your setup something like:
SBS server -- LAN --- UC520 ---- INTERNET -- -Remote site / client
You want the remote site to access certain services from the SBS server (such as HTTP 80, HTTPS 443, Remote Desktop 3389 etc) - you setup a static NAT with the ports above using the WAN IP address on the UC520 and mapping to internal IP address 192.168.16.2?
Is the UC520 WAN IP address a publicly routable IP address from XO? I guess XO has some device in front of the UC520 terminating the T1 and if that is doing a NAT it may cause an issue as the port numbers would change. Also if XO device has a firewall blocking certain ports this may fail as well
The other area to look at - on the UC520 is the firewall blocking the specific ports? Can you upload the config for the UC520? Also, what CCA version did you use
7bridgesol Mon, 04/20/2009 - 10:23
got it.  Also, please note I had to add port 4125 remote web workplace.
Thanks for all your help.
