how to get specific interim release?
Answered Question
Apr 14th, 2009
hey...
Advisory ID: cisco-sa-20090408-asa describes a vulnerability that applies to an ASA 5520 I administer.
The advisory page, http://www.cisco.com/warp/public/707/cisco-sa-20090408-asa.shtml, says this:
8.0(4)25: earliest fixed version,
8.0(4)28: recommended version.
But, the Interim Sofware download page is confusing. There's a version 8.0.4.23, released 04-FEB-2009, but that version doesn't fix the problem. There's a version 8.0.4.3, but the release date, 11-SEP-2008, is far in the past.
For v8.1,
8.1(2)15: earliest fixed
8.1(2)19: recommended.
But, on Interim Software download page, most recent version is 8.1.2.13 (04-FEB-2009).
I have support contracts that are in the process of being renewed, so if I need TAC for this, I'll have to wait.
Is there some other location to find the releases specified in the advisory?
tia...
Correct Answer by burtonwindle about 7 years 11 months ago
it is hard to find for some reason, but its in the advisory:
"Fixed Cisco ASA software can be downloaded from:
http://www.cisco.com/pcgi-bin/tablebuild.pl/ASAPSIRT
Fixed Cisco PIX software can be downloaded from:
http://www.cisco.com/pcgi-bin/tablebuild.pl/PIXPSIRT
Overall Rating: 5 (2 ratings)
Richard Burts Tue, 04/14/2009 - 10:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Linnea
It was not obvious, but I found where the fixed releases can be found. One place in the advisory talking about obtaining fixed software indicates that you should go through normal software download processes and locations. But as you have found out the fixed releases are not on the normal software download pages.
In the advisory is a small note in the section describing the fixed versions. It says:
I followed that link and got to a page with PSIRT images from which I was able to download version 8.0(4)28. Note that this requires a CCO ID with software download privileges. If that is a problem there is a note in the advisory about how people can contact TAC for assistance in getting fixed releases. If you have a problem with the download of PSIRT images you might give a try at calling the TAC.
Rick
linnea.wren Thu, 04/16/2009 - 16:07
Hey...
Sorry for the late acknowledgement.
Thank you both for the solutions provided.
Linnea
