Open SSID configured but clients are seeing WPA
Answered Question
There are about 30 autonomous access points in this building. The are all configured with two SSIDs, each on their own VLAN. For some reason, clients started seeing the public SSID as WPA protected. It is an intermittant problem so I'm not sure what's happening. I sniffed around with Airmagent Spectrum Analyzer and all the public SSIDs are showing as open (without WEP, WPA, etc.). I matched all the radio interfaces from Airmagnet with the AP radios so I know there isn't some rogue around. The AP's are running 12.3.8. Here is the config:
version 12.3
no service pad
service password-encryption
hostname AP20
enable secret
username Cisco password 7 062506324F41
ip subnet-zero
no aaa new-model
dot11 network-map
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 mode ciphers tkip wep128
ssid GUEST
vlan 3
authentication open
guest-mode
ssid LSD
vlan 2
authentication open
authentication key-management wpa optional
wpa-psk ascii 7
short-slot-time
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
channel 2462
station-role root
interface Dot11Radio0.2
encapsulation dot1Q 2 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
speed 100
full-duplex
interface FastEthernet0.2
no ip route-cache
bridge-group 1
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface BVI1
ip address 172.x.x.x 255.255.0.0
no ip route-cache
ip default-gateway 172.x.x.x
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
access-list 111 permit tcp any any neq telnet
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
I've tried my iphone and it connects just fine but an Intel 3945 and Dell card don't always see the SSID as open. Since this is a guest network, clients should be able to bring in any kind of client. I think this is a combo client/AP problem.
Correct Answer by Johannes Luther about 7 years 10 months ago
I guess this is what happens:
The AP is broadcasting the guest SSID. But it also sends beacons with the WPA SSID (non-broadcasting). Both SSIDs use the same BSSID (AP MAC address).
So the client sees the following:
- Beacon: SSID "guest" with no encryption (BSSID: 00:11:22:33:44:55)
- Beacon: SSID "" with WPA (RSN) (BSSID: 00:11:22:33:44:55)
I guess this is confusing some clients. The same BSSID is sending different beacon frames.
A workaround would be to use MBSSIDs. So each SSID is using it's unique BSSID. So each SSID has it's own virtual AP.
See this link for mbssids:
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap7-mbssid.html#wp1050170
Overall Rating: 5 (1 ratings)
Correct Answer
Johannes Luther Tue, 04/14/2009 - 12:34
Thanks for the prompt reply. I tried enabling mbssid and verified through "show dot11 bssid" that I now had unique identifies:
Interface BSSID Guest SSID
Dot11Radio0 0012.80ed.6980 Yes GUEST
Dot11Radio0 0012.80ed.6981 No LSD
However, the problem still shows up. I have a TAC case open but they are having trouble with this too. Any other help would be appreciated.
Thanks again!
Tony
Enabling mbssid did solve the issue. I had to enable it on both SSID's. Here are the changes made from the original config:
dot11 ssid GUEST
vlan 3
authentication open
mbssid guest-mode
dot11 ssid LSD
vlan 2
authentication open
mbssid dtim-period 2
wpa-psk ascii 7 (hidden)
interface dot11radio 0
mbssid
Also, removing the WEP128 and optional security was a recommendation.
Thanks again!
Johannes Luther Tue, 04/21/2009 - 10:21
I'm glad that helped. Sorry - I couldn't follow up your first reply.... this one sneaked through my fingers :-)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
