Copy one CCM database to another CCM
Apr 14th, 2009
I have 2 clusters of CCM. the target is to consolidate both clusters with one publisher and 3 suscibers. is there any manner to copy the database from one of them into the second CCM that will be the Publisher ?
Jaime Valencia Tue, 04/14/2009 - 17:19
unfortunately no, there are far too many dependencies in the whole DB to try to merge them without causing the server to die. if they're in the same version the safest bet is to use bat to export/import the information for phones. all other stuff will need manual work.
remember things like MRGL and plenty of other stuff needs to be created before importing.
if this helps, please rate
