04-14-2009 01:34 PM - edited 03-13-2019 06:15 PM
We are running ccm 5.1.3 and have an MGCP CAS T1 connected to another phone system. I would like to know if there is a way to present a predefined name on inbound calls from that T1 tie trunk. Currently we get unknown name when receiving a call. I know caller ID doesn't work but can I define a trunk group name to display so at least our users know what location is calling. We don't need the number at this point.
04-14-2009 05:49 PM
On the voice port you should be able to configure:
voice-port 0/0/0:0
station-id [name] | [number]
-nick
04-15-2009 10:55 AM
Thanks for the reply but it did not work for me. I don't see the station ID name or number when receiving a call. Does something need to be enable or disable to allow me to see it?
04-15-2009 11:39 AM
Sorry, for MGCP you would need to do this in CUCM.
It looks like in the Port configuration of the T1 you can specify a Caller ID DN. I would try putting the ID there, resetting the gateway, and seeing if this helps.
hth,
nick
04-15-2009 11:46 AM
Sorry, didn't work. I just put in a 5 digit number for the DN and it didn't come up. I did reset the gateway as suggested. Thank you.
04-15-2009 01:52 PM
It sounds like you won't be able to do this on T1 CAS. If you had a fgd-eana circuit you can receive ANI on that, however.
hth,
nick
04-15-2009 11:32 AM
