CSS 11503 - load balancer Tomcat web server
Apr 14th, 2009
I am new to the CSS 11503. I am looking for sample configurations on loadbalancing a pair of Tomcat web server applications on port 8080. Any assistance will be greatly appreciated.
Overall Rating: 5 (1 ratings)
dario.didio Tue, 04/14/2009 - 22:59
  • Silver, 250 points or more
on this link you can find all available config guides:
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_installation_and_configuration_guides_list.html
and on this link you can find config examples:
http://www.cisco.com/en/US/products/hw/contnetw/ps792/prod_configuration_examples_list.html
If any other specific questions, don't hesitate to post them.
HTH,
Dario
sachinga.hcl Wed, 04/15/2009 - 17:45
I have a CSS 11501 on which I managed to configure a fake SSL on the
device itself.
Behind the CSS, I have 2 Tomcat servers listening on port 8754.
These 2 Tomcat servers do not have any "Web Servers" like Apache or
IIS which would normally listen on port 80.
With my config below, when I hit the Virtual IP of the CSS, httpS://10.136.2.46/,
I get a prompt for a SSL Certificate warning but since I know its a
fake SSL, I say OK (I use IE 7) and proceed to the site. Then I see a
login page (httpS://....../welcome.do) and as soon as I login with my
credentials, I get re-directed to URL http://10.136.2.46/ instead of
keeping httpS://.....
My intent is to have an httpS:// session maintained throughout with
CSS accepting the incoming encrypted message, does the authentication,
decrypts the message to HTTP and forwards the client request to Tomcat
on port 8754.
Once the results are back from Tomcat, CSS should re-encrypt it and
send the results back to the same client via HTTPS.
CSS11501# show running-config
!Generated on 08/23/2007 16:45:45
!Active version: sg0730005
configure
!*************************** GLOBAL ***************************
ssl associate rsakey keyname keyfile
ssl associate cert certfile certfile
ip route 0.0.0.0 0.0.0.0 10.136.2.254 1
!************************** CIRCUIT **************************
circuit VLAN1
ip address 10.136.2.47 255.255.255.0
no redirects
!*********************** SSL PROXY LIST ***********************
ssl-proxy-list ssl_virtual_server
ssl-server 20
ssl-server 20 vip address 10.136.2.46
ssl-server 20 rsacert certfile
ssl-server 20 rsakey keyname
ssl-server 20 cipher rsa-export-with-rc4-40-md5 10.136.2.46 80
weight 5
ssl-server 20 urlrewrite 22 10.136.2.46 sslport 443 clearport 8754
active
!************************** SERVICE **************************
service http_web1_svc
ip address 10.136.2.20
protocol tcp
port 8754
keepalive type http
active
service http_web2_svc
ip address 10.136.2.48
protocol tcp
port 8754
keepalive type http
active
service https_sslvirtualweb_svc
type ssl-accel
slot 2
keepalive type none
add ssl-proxy-list ssl_virtual_server
active
!*************************** OWNER ***************************
owner NON-SSL
content http_rule
sticky-inact-timeout 150
advanced-balance sticky-srcip
balance leastconn
protocol tcp
port 80
add service http_web1_svc
add service http_web2_svc
active
owner SSL
content https_rule
protocol tcp
port 443
add service https_sslvirtualweb_svc
sticky-serverdown-failover sticky-srcip
application ssl
advanced-balance ssl
active
!*************************** GROUP ***************************
group virtual_web_server_pool
add destination service http_web1_svc
add destination service http_web2_svc
active
CSS11501#
contnued in 2nd page below.........
continued from page 1....
2nd Example:
Basically, I use SSL termination on CSS's SSL module and it seems no work for the web server using tomcat. The tomcat server insists to use http, not https. (The server always indicate client to query a URL with http head, not a URL with https head.)
Is it possible to change the behavior from CSS? My configuration is:
ssl-proxy-list ssl-slot3
ssl-server 19
ssl-server 19 vip address 10.1.1.19
ssl-server 19 rsakey testRSAkey
ssl-server 19 rsacert testCAcert
ssl-server 19 cipher rsa-with-rc4-128-sha 10.4.98.19 81
service test-backendserver-8080
ip address 10.3.3.29
protocol tcp
port 8080
keepalive type tcp
keepalive port 8080
active
content ssl-test-rule
protocol tcp
port 443
add service ssl-slot3-srv
active
content ssl-test-rule2
vip address 10.2.2.19
protocol tcp
port 8080
add service test-backendserver-8080
balance leastconn
active
My tomcat server is either using absolute path (so link like http://.....) in this case the only thing you can do is modify the server, or the tomcat server is sending a redirect to the client to http://....
The SSL-mod can intercept the redirect and rewrite it to HTTPS.
So I need to add a command 'ssl-server 19 urlrewrite 1 * sslport 443 clearport 8080'
A sniffer trace would tell us why the client keeps using http.
if it is absolute path, can we use backend-ssl configuration to achive L5 load balancing (with stickness)?
I do not see the benefit of doing backend ssl if the frontend is cleartext.
Unless the CSS is on the clientside and you want to go accross the internet to the server.
In this case, yes, backend ssl could be a solution.
But verify first with a sniffer trace what is going on.
Tomcat's native behavior is to generate
absolute URL's on all redirects. And that cannot be changed.
To fix it is to change configuration on tomcat to treat CSS as a proxy server.
Also get lots of cisco css config examples here below mentioned URL:
1. Configuration Examples and TechNotes
2. CSS product support page
http://www.cisco.com/en/US/products/hw/contnetw/ps789/tsd_products_support_eol_series_home.html
3. Design TechNotes
http://www.cisco.com/en/US/products/hw/contnetw/ps789/tsd_products_support_design_technotes_list.html
4. Configuration guides:
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_installation_and_configuration_guides_list.html
Hope it iwll help some.
Still get in touch for any further discussion.
Best Regards,
Sachin
sachinga.hcl Wed, 04/15/2009 - 17:56
page 3.....
I also have configured for some companies 2 CSS's as load balancers for a bunch of web servers and they work great . When a web daemon on a server crashes, or is shutdown for one reason or another, the CSS removes that service from the pool, which is good, but that server looses connection to the outside world. We can still SSH into the server and push data onto it, but the route to the outside world is dead.
This was the problem since our servers often need to connect to outside resources on startup.
We were currently set up with a 2-Tier network layout where the CSS is connected to our public network (say 198.202.0.0/24) and our servers sit on a private network(192.168.0.0/24) and use the CSS as their gateway.
I tried a number of fixes to rectify the situation, but nothing has worked so far. The servers have another NIC connected directly to the public network, but since the default GW is the CSS, it does not help. I tried changing the default GW on the servers to point to our public GW, but then access through the CSS VIP does not work. Static routes don't do the trick either.
I try to find is there any configuration option that I can change so that the CSS does not kill the GW for a server whose service is down?
Either that, or do you know of a better way to lay out the configuration so we avoid the problem?
Later on going through various reference guides I find some solution as follows:
CSS by default acts as a router but you need to translate the Real server's ip for server originated traffic.
To have the CSS nat traffic initiated by the server side you need to add a "source group" into the CSS config. Here is what you need:
group
vip address
add service
add service
etc...
active
This will force the CSS to NAT server initiated traffic.
We already have groups set up for the servers. I have attached our config file (slightly edited for security reasons) to see our setup.
Here are some more details on our setup.
General:
Public Network: 198.202.0.0/24
Private Network: 192.168.0.0/24
Public Gateway: 198.202.0.13
CSS IP: 198.202.0.1
CSS Gateway: 192.168.0.1
Server Network Setup:
Default Gateway -> CSS Gateway (192.168.0.1)
Eth0 198.202.0.10#
Eth1 192.168.0.10#
As I said, while the Tomcat daemon is running, the server can ping to the outside world through the CSS, but as soon as the daemon is stopped, the keepalive detects it as down, removes it from the pool and drops all outgoing packets from that server.
you try using a different IP (other than 198.202.0.51 )in group configuration.
group webservers
add service http2
add service http3
add service http1
vip address 198.202.0.x
active
....continuue to page 4
sachinga.hcl Wed, 04/15/2009 - 17:59
page 4.....
Complete config after few changes in real ip address seems as follows:
!Generated on 23/11/2007 09:33:21
!Active version: sg0750004
configure
global-portmap base-port 3000 range 30000
bridge spanning-tree disabled
cdp run
sntp primary-server 132.249.0.88 version 1
username admin des-password xxxxxxxxxxx superuser
no restrict web-mgmt
app
app session 198.202.0.2
logging subsystem syssoft level notice-5
logging subsystem buffer level notice-5
logging subsystem flowmgr level notice-5
logging subsystem radius level notice-5
logging subsystem wcc level notice-5
logging subsystem ipv4 level notice-5
logging subsystem chassis level notice-5
logging subsystem vlanmgr level notice-5
logging subsystem netman level notice-5
logging subsystem app level notice-5
logging subsystem rip level notice-5
logging subsystem ospf level notice-5
logging subsystem sntp level notice-5
logging subsystem dhcp level notice-5
logging subsystem vrrp level notice-5
logging subsystem redundancy level notice-5
logging subsystem csdpeer level notice-5
logging subsystem portmapper level notice-5
logging subsystem circuit level notice-5
logging subsystem security level notice-5
logging subsystem fac level notice-5
logging subsystem vpm level notice-5
logging subsystem publish level notice-5
logging subsystem acl level notice-5
logging subsystem keepalive level notice-5
logging subsystem urql level notice-5
logging subsystem nql level notice-5
logging subsystem dql level notice-5
logging subsystem pcm level notice-5
logging subsystem proximity level notice-5
logging subsystem hfg level notice-5
logging subsystem replicate level notice-5
logging subsystem boomerang level notice-5
logging subsystem fp-driver level notice-5
logging subsystem flowagent level notice-5
logging subsystem cdp level notice-5
logging subsystem asr level notice-5
logging subsystem natmgr level notice-5
logging subsystem ssl-accel level notice-5
logging subsystem perform level notice-5
logging subsystem sshd level notice-5
logging subsystem reporter level notice-5
dns suffix sdsc.edu
dns primary 198.202.0.26
dns secondary 132.249.0.26
ip route 0.0.0.0 0.0.0.0 198.202.0.13 1
!************************* INTERFACE *************************
interface 1/1
description "front-side network"
bridge vlan 522
interface Ethernet-Mgmt
phy 10Mbits-FD
interface 2/1
description "back-end network"
bridge vlan 525
circuit VLAN522
ip address 198.202.0.1 255.255.255.0
circuit VLAN525
ip address 192.168.0.1 255.255.255.0
!************************* KEEPALIVE *************************
keepalive get-homepage1
description "HTTP GET Keepalive for HTTP1"
ip address 192.168.0.101
method get
frequency 15
retryperiod 15
type http
uri "/pdb/cssKeepAlive.do"
active
keepalive get-homepage2
ip address 192.168.0.102
description "HTTP GET Keepalive for HTTP2"
type http
method get
frequency 15
retryperiod 15
active
keepalive get-homepage3
ip address 192.168.0.103
description "HTTP GET Keepalive for HTTP3"
type http
method get
frequency 15
retryperiod 15
active
......continue to page 5
page 5.....
service http1
port 80
keepalive type named get-homepage1
keepalive port 80
active
service http2
keepalive port 80
keepalive type named get-homepage2
port 80
active
service http3
keepalive port 80
keepalive type named get-homepage3
port 80
active
owner pdb
content pdb-http
protocol tcp
port 80
advanced-balance sticky-srcip-dstport
add service http2
add service http3
add service http1
vip address 198.202.0.51
active
group webservers
add service http2
add service http3
add service http1
active
Hope it will be of some help to you..
Sachin
kin.mak Thu, 04/16/2009 - 03:50
Thank you very much Sachin. The configurations you provided are very helpful.
sachinga.hcl Thu, 04/16/2009 - 07:40
Hi Kin,
Could you please rate if possible .
Kind regards,
sachin
