Inbound SIP call failure
Apr 14th, 2009
I have managed to get calls outbound but I cant seem to get inbound from a sip trunk.
SIP Provider-->Internet-->SR520-->UC520
debug from UC520 - debug ccsip call
000455: Apr 10 03:14:49.246: //-1/95B1D1FB80EF/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x8661DDC0
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : XXXXXXXXX
Called Number : 04974XXXX
Source IP Address (Sig ): 192.168.75.2
Destn SIP Req Addr:Port : 202.180.76.161:0
Destn SIP Resp Addr:Port : 202.180.76.161:5060
Destination Name : 202.180.76.161
000456: Apr 10 03:14:49.246: //-1/95B1D1FB80EF/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 63
Disconnect Cause (SIP) : 500
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
voice translation-rule 1
rule 1 /04974XXXX/ /201/
voice translation-profile SIP
translate called 1
access-list 1 permit 202.180.76.166
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Generic SIP Trunk Provider) **
translation-profile incoming SIP
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
incoming called-number 049748064
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
Can any one shed some light as to why my inbound calls are failing? I cant seem to see the light at the moment
Many thanks
ok removed the following as a result of another post:
voice source-group CCA_SIP_SOURCE_GROUP
access-list 1
translation-profile incoming SIP_Incoming
And now I am getting the following debug:
UC520#
000458: Apr 10 03:34:07.678: //189/47FF564A80F3/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x8659A864
Destn SIP Req Addr:Port : 202.180.76.161:5060
000459: Apr 10 03:34:07.678: //189/47FF564A80F3/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 2
Media Stream : 1
Negotiated Codec : g729r8
Negotiated Codec Bytes : 20
Nego. Codec payload : 18 (tx), 18 (rx)
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 192.168.75.2
Source IP Port (Media): 16978
Destn IP Address (Media): 202.180.76.161
Destn IP Port (Media): 38418
Orig Destn IP Address:Port (Media): 0.0.0.0:0
000460: Apr 10 03:34:07.678: //189/47FF564A80F3/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 2
Negotiated Codec :
Negotiated Codec Bytes : 0
Nego. Codec payload : 0 (tx), 0 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Port (Media): 18658
Destn IP Port (Media): 35834
000461: Apr 10 03:34:07.678: //189/47FF564A80F3/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 17
Disconnect Cause (SIP) : 486
Now I understand disconnect 486 to be a busy phone. This was on hook
Maulik Shah Tue, 04/14/2009 - 21:57
  • Silver, 250 points or more
Can you post the complete config and the version on the UC520 on this thread?
Also, the second issue appears to be a cause code of user busy. Can you gather "deb ccsip message" for one inbound failed call and attached as well
By the way - who is your SIP provider?
