Voice translation rule - extra IVR options automatically inserted
Apr 14th, 2009
Is there a possibility to merge a pause between a number so that after dialing a normal number extra IVR options automatically can be inserted?
What whe want to do is:
call the number, wait one second, send the dtmf number 1, wait one second, send another number ending with a #.
An example:
0612345678p1p0687654321#
where p is standing for a pause.
Is this possible with a voice translation rule or can we use a voice XML script or something else?
What is the configuration whe need?
Thanks in advance,
Best regards,
Ruben de Haas
irisrios Mon, 04/20/2009 - 14:07
  • Silver, 250 points or more
CallManager does NOT support interdigit pauses. Wildcard Symbol “T” Used in Destination Pattern indicates the interdigit timeout. The router pauses to collect additional dialed digits.
You can use a comma (,) to include a one-second pause between digits to allow for a secondary dial tone.
