ACE performance issues
Apr 14th, 2009
I'm testing an ACE module in a 6509 chassis. I am using ACE firmware c6ace-t1k9-mz.A2_2_0.bin.
I use a script which replaces the variables of the following config with something unique to insert vips.
Config:
class-map match-all TEST_CLASS_%NUMBER%
match virtual-address 172.31.1.200 tcp eq %NUMBER%
rserver host TEST_RSERVER_%NUMBER%_1
ip address %IP1%
inservice
rserver host TEST_RSERVER_%NUMBER%_2
ip address %IP2%
inservice
serverfarm host TEST_SFARM_%NUMBER%
predictor leastconns
probe PING
rserver TEST_RSERVER_%NUMBER%_1 %NUMBER%
inservice
rserver TEST_RSERVER_%NUMBER%_2 %NUMBER%
inservice
policy-map type loadbalance first-match TEST_POLICYMAP_%NUMBER%
class class-default
serverfarm TEST_SFARM_%NUMBER%
policy-map multi-match VLAN1000-POLICYMAP
class TEST_CLASS_%NUMBER%
loadbalance vip inservice
loadbalance policy TEST_POLICYMAP_%NUMBER%
loadbalance vip icmp-reply
nat dynamic 1 vlan 1000
End of config.
The complete config of my context before inserting new vips is:
logging enable
logging console 7
access-list ALLOWALL line 8 extended permit ip any any
probe icmp PING
interval 600
faildetect 2
class-map type management match-all SSHMNGT
2 match protocol ssh any
class-map type management match-all TELNETMNGT
2 match protocol telnet any
class-map type management match-all WEBMNG
2 match protocol http any
class-map type management match-all WEBSMNG
2 match protocol https any
policy-map type management first-match POLICY_MNGT
class SSHMNGT
permit
class TELNETMNGT
permit
class WEBMNG
permit
class WEBSMNG
permit
interface vlan 115
ip address 172.31.3.6 255.255.255.0
access-group input ALLOWALL
access-group output ALLOWALL
nat-pool 1 172.31.2.12 172.31.2.12 netmask 255.255.255.255 pat
no shutdown
interface vlan 901
ip address 172.16.15.6 255.255.255.0
service-policy input POLICY_MNGT
no shutdown
interface vlan 1000
ip address 172.31.0.6 255.255.255.0
nat-pool 1 172.31.2.13 172.31.2.30 netmask 255.255.255.255 pat
service-policy input VLAN1000-POLICYMAP
no shutdown
ip route 10.53.0.0 255.255.0.0 172.31.0.118
username www password 5 *************** role Admin domain default-domain
username admin password 5 *************** role Admin domain default-domain
End of complete config.
Now i generate the config of 1000 vips, upload it to the ace and merge it with the running config.
It goes well, it works but the process takes about 20 minutes...
Now I continue until I have added a total of 4000 vips and notice it takes a very long time to complete.
While the ACE is merging the config, the ACE takes about 30 seconds to accept a command. Sometimes I even get API timeouts.
Ah well, I can live with that. What does bother me a lot is that booting my context takes one hour!!! when it is fully loaded.
Can anybody tell me I am doing something wrong or is this by design?
With kind regards,
Tom van Leeuwen
Gilles Dufour Fri, 04/17/2009 - 05:40
  • Cisco Employee,
When the congig grows too big, this was somehow normal behavior.
We tried to improve this in version A2(2.0)
We have reduced merge/boot time to 45 seconds.
Gilles.
siennax Mon, 04/20/2009 - 04:32
I am using firmware c6ace-t1k9-mz.A2_2_0.bin. So I'm already having that and that is not the problem then... Still haven't found a reason why it takes so long...
