ipcc express : contacts waiting
Apr 15th, 2009
Hi list,
Requirement : There should be only one call in queue for IPCCX.
Tried using "Get Reporting Statistics" step under queued step with combination of "contacts waiting" from overall IPCC Express/ CSQ IPCC Express but no luck.
I have selected "resulting statistics" as string variable.
Has anybody got this working?
Chris Deren Wed, 04/15/2009 - 07:00
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Sure, set it as integer and then simply do an if statement to see if the vlaue is >=1. Also, make sure you are doing this for the correct CSQ.
HTH,
Chris
