Call Server not coming up
Answered Question
Apr 15th, 2009
ICM 7.5
CVP 7.0
The call server is not coming up.
here is the log from voice browser.
13:15:08 Initializing Event Management System (EMS) Library.
13:15:08 Trace: EMS Server pipe Customer\Voice Browser\VBEMSPipe enabled for Customer\Voice Browser\VB
13:15:08 Trace: Release 7.0.1, Build 1190
13:15:08 Trace: INFO: Registry base = CVP\Customer\Voice Browser
13:15:08 Trace: INFO: Process Name = VB
13:15:08 Trace: INFO: ICRRoot = C:\Cisco\CVP\bin
13:15:08 Initializing Node Manager Library.
13:15:08 Trace: INFO: Voice Browser Reading Registry...
13:15:08 Trace: Monitor Server pipe Customer\Voice Browser\VBCmdPipe enabled for Customer\Voice Browser\VB
13:15:08 Trace: Monitor Server pipe Customer\Voice Browser\VBReadOnlyCmdPipe enabled for Customer\Voice Browser\VBReadOnly
13:15:08 Trace: INFO: Voice Browser initializing globals...
13:15:08 Trace: INFO: VBRegistry::SetRegNotify Setting Registry trace
13:15:08 Trace: INFO: Voice Browser starting threads...
13:15:10 Trace: INFO: Resolving IP address for ICMGRPCVP1
13:15:12 Trace: INFO: IP address for ICMGRPCVP1 is 10.20.20.60
13:15:12 Trace: INFO: Gatekeeper configured is 10.20.61.92;SIDEA;1719. Registration attempts will start with first GK in this list until a successful registration occurs
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: maxCalls(defined in radvision config as Q931.maxCalls) = 1400
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: maxIVRPorts = 130
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: maxTotalCalls = 555
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: takebackPercentage = 0
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: startingRtpPort = 16384
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: radConfigPath = C:\Cisco\CVP\VoiceBrowser\Config.val
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: pktInterval = 20
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: adminMode = 1
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: RaiMaxThreshold = 90
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: RaiMinThreshold = 80
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: Codec = g711Ulaw64k
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: CpuMaxThreshold = 99
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: CpuMinThreshold = 94
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: CpuHealthCheck = 0
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: CpuSustainedTime = 15
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: CpuOverloadReject = 0
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: PerfmonIntervalTimer = 5000
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: MemMaxThreshold = 80
13:15:12 Trace: INFO: H323CallMgr::getRegistrySettings: MemMinThreshold = 60
13:15:12 Trace: INFO: Voice Browser Main Thread Active...
13:15:12 Trace: INFO: H.225 Call signalling address of Voice Browser is 10.20.20.60:1720
13:15:12 Trace: INFO: Voice Browser Trace Mask is 0x101083
13:15:12 Trace: INFO: Initial registration with gatekeeper
13:15:12 Voice Browser communication to the Gatekeeper successful, alarm cleared.
13:15:12 Trace: SYSLOG: Server: STATUS=2, Port: =H323,NAME=H.323Ser?+wSTATUS=2
13:15:12 Trace: INFO: H323CallMgr::sendRAI: Successfully sent RAI for resource unavailability
13:15:12 Trace: INFO: LongPoll Failed -- Got OUT_OF_SERVICE from Call Server
13:15:13 Trace: INFO: Starting HEALTH long poller to Call server localhost:8000/cvp/VBServlet
13:15:13 Voice Browser to Call Server localhost:8000 connection unsuccessful.
13:15:13 Voice Browser cannot access any Call Servers and is no longer accepting calls.
13:15:13 Voice Browser ICMGRPCVP1 is out of service.
13:15:13 Trace: INFO: H323CallMgr::sendRAI: Successfully sent RAI for resource unavailability
Correct Answer by geoff@hp.com about 7 years 10 months ago
That's odd. When you run setup from icm\bin and go to the Peripherals TAB, you normally check the box for the PG you need (in your case PG1 and PG2), then the registry entry you noted for PG02 will be changed from 1 to 0; and the registry entry in Router for PG2 will be changed to 1. They will be set in pairs.
Perhaps you tried to activate the PG without running setup, and did one registry value but not the other.
Geoff
Overall Rating: 5 (2 ratings)
sandeep pokhriyal Wed, 04/15/2009 - 10:44
finally solved the issue.
it was in partial state.
the DeviceDisabled reg key in Router setup for VRU PG number(HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\ICM\customer\RouterA\DMP\CurrentVersion\Devices\PG02) was set to 1.
once changed to 0 it worked. phew..
donno what was the issue and why the key is 1 by default.
Correct Answer
geoff@hp.com Wed, 04/15/2009 - 12:16
Geoff
sandeep pokhriyal Thu, 04/16/2009 - 05:44
thxx Geoff,
that was exactly where we were going wrong.
actually this setup is 7.5 ICM and now we dont check the PG in router setup.
one has to put the exact number of PG in the field that are to be active.
like if you have installed 2 PG's then you can put 1,2 or 1-2 or 1 2 and so forth for more PG's.
In this we just put the number 1(CCM) and obviously that PG was working. we missed out with 2(VRU) and it was down.
We run the setup for both the PG's except that we were missing this VRU PG Number in router setup.
Sheraz Saeed Lodhi Wed, 04/07/2010 - 15:53
sandeep i am facing the same issue in my redundent CVP server while the first one is working fine. in OAMP both cvps are UP and also registered in gatekeeper. the only thing i still need to do is to  upload the license file on CVP B but i don't think this could be the issue. Any help from you guys will be appreaciatble.
Thanks in advance
geoff@hp.com Wed, 04/07/2010 - 17:24
It runs with two active ports without a licence
Are you saying that PIM1 connected to CSA is active, but PIM2 connected to CSB is not active?
1. Run setup and check that you have configured the PIM correctly.
2. If using a hostname, is it resolveable. If using IP address, is there a typo
3. is the port 5000
4. make sure it is enabled
Geoff
Sheraz Saeed Lodhi Thu, 04/08/2010 - 01:02
no , my both PIMs are up and connected. Infact it was working fine and i had about 130 calls on it with out license for testing. But when i stop my CVP A call server and through a call to CVP B for fail over test the got drop and Voice Browser displayed me Out of Service as the call server is not coneected.
Whne i look into Gatekeeper both VBs are up and registered. When i look into OAMP both Call Servers are UP and at PG side both PIMs are UP as well. then why VB is not able to communicate with CS.
geoff@hp.com Thu, 04/08/2010 - 05:21
Do you perhaps have both VBs configured to use the same Application Server, Call Server A, by mistake? Run VBAdmin and check the settings on each one and compare.
Geoff
bilalghayad Sun, 09/18/2011 - 07:09
Dear Geoff;
I am facing the same thing, but in the OAMP is shown to be down and not able to get any statistics on this CVP Call Server.
Actually the PG01, PG02 and PG03 are enabled in the router registry (while PG01 for CUCM PG, PG02 for CVP Call Server PG and PG03 for the Media Routing PG).
It was working before and I was receiving calls on it, but suddenly this happened.
Actually, an upgrade happened from version 7 to version 8 and we imported new licenses for the VXML Server but did not import new licenses for the CVP Call Server. Could be a license issue because we have to import the new license to change from version 7 to version 8?
Thanks in advance for the help.
Bilal
karthikayyappan10 Sun, 01/22/2012 - 00:21
I am having one ICM 7.1.5. I have two CVP servers and I want to add these servers in ICM. For CVP A I have added a PIM and Its fine in BOTH side A and SIDE B ICM.  added one more VRU PIM for CVP B server and it is in idle. I added the PIM in side B ICM server not in Side A and Currently Side A is active and in production.
Each and Every time I rerun the ICM setup, I can not see the VRU PIM 2 for CVP B server.It is not visible too. For this Call server is in Partial Service for a ver long time..
Did any one fased the issue..
Thanks in advance
Karthik
