Attendant access using one digit
Answered Question
Apr 15th, 2009
Hello All,
I want that users, dialing only "9", reaches the attendant that really have extension 2000.
any idea?
Correct Answer by Jaime Valencia about 7 years 11 months ago
i'm going to assume this is CUCM since you don't mention anything else
yes, configure a translation pattern to do that, be aware that if you have anything else using 9 as 1st digit you won't be able to dial it anymore
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 04/15/2009 - 07:33
  • Cisco Employee,
  • Hall of Fame,
    2011
java
iptuser55 Thu, 04/16/2009 - 02:22
  • Silver, 250 points or more
Following the above you could add the translation as 9! so that if you do have anything else starting with 9 it will wait for the t302 to expire.
mcecilia Thu, 04/16/2009 - 03:21
I tried 9 and worked as expected, but if I configure 9!, I have to dial 9 and anything else, not only 9. I have tried with 9. and does not wait, and with 9* and does not work. Any idea about this wilcard?
Only 9 works as expected. I do not need to do more, but maybe we can learn anything more for the future. Many thanks.
